Help with WJ Complete System Swap - JeepForum.com
post #1 of 4 Old 08-28-2011, 03:00 PM Thread Starter
peytonimor7
I have the Infinity system in my WJ with the amp under the rear seat. Right now I have a Pioneer DEH 11E head unit. I will eventually upgrade to a HU with 6 pre amp outputs, but for now I'm keeping the HU.
In the next few days I'll probably order some front speakers/ dash speakers. Sometime in the future I'll upgrade to a 4 channel amp to replace the stock Infinity. I'll also add a sub in the future.
Scenario A: Add components to the front and mount the tweeters in the dash, this way i'll have only 4 channels, all powered by a 4 channel amp I'll eventually get. Then, get a two channel amp and bridge it for the sub, so if I ever want two subs I can easily plug it into the two channel.
Scenario B: Have two 4 channel amps, one to power the door speakers, and use the other one to bridge it to 3 channels, using two channels for dash speakers and the 3rd for a sub.
Which would be the better option for me? And if I go with B, could I just add 5$ bass blockers to each tweeter instead of buying crossovers?
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #2 of 4 Old 08-28-2011, 04:01 PM
wsar10
2003 WJ
Option A,
but get a mono amp and with DVC subs you have a million diff. wiring options. Amps do not know channles all they see is an ohm load.
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #3 of 4 Old 08-29-2011, 01:33 PM Thread Starter
peytonimor7
Ok what's the benefits of DVC subs? When I could just wire it the regular way to a mono sub?
post #4 of 4 Old 08-29-2011, 02:00 PM
wsar10
2003 WJ
The only real word benefit is, with two voice coils you have a few diff. wiring options.
that means more options if you ever wanna upgrade, also more amplifier choices
If your always gonna be ok with your given setup than no need for DVC really.
My WJ (our family vehicle) has just a SVC infinity sub and its perfect for the application, my DD has two DVC sub.
wsar10 is offline
audio , complete , rebuild , system
Need to locate one more part to complete this swap for my D44 Lud04X Engines & Drivetrain 2 02-22-2007 10:38 AM
Complete sound system replacement mountainwolf Audio, CB & Ham Radios, GPS, & Electrical 0 11-23-2005 12:42 PM
Complete new sound system and 8" Sub Dctjwrangler01 Audio, CB & Ham Radios, GPS, & Electrical 10 03-07-2005 07:55 PM
sound system complete.....i think widdowmaker Audio, CB & Ham Radios, GPS, & Electrical 4 01-30-2005 09:44 PM
Complete Audio System Install JeepLib03 Audio, CB & Ham Radios, GPS, & Electrical 9 06-01-2004 09:30 AM
