help with stereo in Tuffy console install - JeepForum.com
post #1 of 5 Old 04-01-2006, 05:38 PM Thread Starter
Johnny World
Johnny World's Avatar
hey guys, ok, my tuffy console and stereo are here. I have a pretty good idea on what I need to do to make this work but had a couple of remaining questions:
1. The antenna wire isn't long enough. So i went to Radio Shack and asked if they had but no go. Does anyone know the technical term for this wire? also, would it be easier to undo the plug crimp and solder extra wire? or just get the whole wire new and reconnect to the antenna base and plug crimp?
2. I bought some Radio Shack hook up wire, specs are rated 300 volts, 18 gauge. Will this wire be ok to bridge the wires from the factory harness to the stereo harness?
3. When you slide in the stereo into the console, I noticed that there is a little bit of play, room for the stereo to move around side to side. Since this is metal to metal, did anyone put anything in between to sorta cushion everything?
Thanks guys for the input, will post pics when i'm done.
'02 WJ, Laredo Special Edition, 4.0L I6
Johnny World is offline
post #2 of 5 Old 04-01-2006, 08:14 PM
EaglesSJ
EaglesSJ's Avatar
1. walmart sells antenna wire in the auto section
2. that wire will be fine.
3. Is the stereo mounting frame loose in the console or the stereo loose in the frame?
EaglesSJ is offline
post #3 of 5 Old 04-01-2006, 10:09 PM
tctrjeep
You can look at the following for some mounting options...
http://www.commtechreview.net/jeep/tuffy1.htm
http://www.commtechreview.net/jeep/tuffy2.htm
These detail how we installed some radio gear that was not standard DIN size. Might give you some ideas.
tctrjeep is offline
post #4 of 5 Old 04-01-2006, 10:59 PM Thread Starter
Johnny World
The stereo mounting frame is loose in the console. Again, it's not alot, my main concern is skipping while playing cd's.
post #5 of 5 Old 04-03-2006, 12:36 PM
mascmatt
On the hunt
mascmatt's Avatar
2014 JK Wrangler
I installed the same thing about a year ago. Did you make sure you have the radio in the silver bracket and then put into the consol? Also abotu the wire. Igot my extension from pepboys.
mascmatt is offline
How do I wire a stereo in a Tuffy Center console? lilirish10245 Audio, CB & Ham Radios, GPS, & Electrical 5 01-13-2010 07:05 PM
Tuffy Stereo Console PICS? sgrim80 Audio, CB & Ham Radios, GPS, & Electrical 35 09-23-2005 05:11 PM
Tuffy stereo console + system install ?'s wyldejackyl Audio, CB & Ham Radios, GPS, & Electrical 22 02-27-2005 08:02 PM
What stereo in Tuffy stereo console? wyldejackyl Audio, CB & Ham Radios, GPS, & Electrical 3 09-25-2004 01:15 PM
Best CD Player for the Tuffy Stereo Console? Roadkill43 Audio, CB & Ham Radios, GPS, & Electrical 2 08-13-2004 12:21 PM
