Help with Speaker size? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Help with Speaker size?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 11-28-2004, 06:32 PM   #1
moush
hey bros, I am planning on upgrading my speakers in my 98 Wrangler. Can i change the speakers in the sound bar? If so anyone know the size of them? Also I wanted to change the front speakers...what size are those?
moush is offline   Reply With Quote
Unread 11-28-2004, 06:35 PM   #2
djcarter
I have a rubi with the 7 speaker system so my fronts are 4inch, but if you have a 4 speaker system I believe it will go like this.
front: 4x6's
rear: 5.25's
I believe a company makes a bracket so you can install 5.25's in the front as well.
djcarter is offline   Reply With Quote
Unread 11-28-2004, 06:48 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The soundbar can, without modification, accept non-S style 6.5" speakers. S-style 6.5" speakers have a deeper speaker depth due to a bigger magnet so they won't fit.
The TJ's front speakers are 4x6 but they have a non-standard frame size which means aftermarket 4x6 speakers won't fit. Probably the best thing you can do is buy one of the speaker adapters made for TJs and install a better sounding round 5.25" speaker. Go to this website for the (overpriced) speaker adapters.... http://www.offroadtoystore.com/Merch...t_Code=33-5100
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 11-28-2004, 07:49 PM   #4
moush
so if i get this expensive bracket I can put 5.25 speakers in the front, right? Now what about the sound bar? What is the non-s and s-style speakers? Could you send me a link to a non-s stle speaker? How can i find out if it is non-s style?
Unread 11-28-2004, 09:13 PM   #5
BigWaylon
tubework is cool...
BigWaylon's Avatar
shop around on Crutchfield to see the "S" and "non-S"...then go buy them somewhere cheaper...
I wouldn't waste the $25 on the brackets...buy the $10 version here:
http://www.mjmautoinnovations.com/sakj46t525.htm
and yes, you can run 5.25" speakers in the front that way...
I either buy four of the same 5.25", or a pair of 5.25" for the front and a pair of 6.5" (of the same "line" of the same brand) for the roll bar...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Unread 11-29-2004, 04:38 PM   #6
moush
hey bigwaylon....how would 6.5 speakers fit in the sound bar??
Unread 11-29-2004, 07:40 PM   #7
BigWaylon
tubework is cool...
BigWaylon's Avatar
I'm running 5.25" in mine...
but, as I understand it, a 6.5" will fit simply by drilling 4 new holes for the screws...they'll drop right into the openings...
this is for the roll bar...not sure about the new wedges in the TJ...
Greg
Unread 11-30-2004, 10:26 AM   #8
SirGCal
SirGCal's Avatar
Some 6.5" even come with their own adapter ring (the Alpine SPS-170A's for example). These smaller 6.5" speakers are commonly swapped where 5.25" were normal so these rings are sometimes included in todays packaged speakers. If not, as BW suggested, just simply drilling 4 new holes will often mount the 6.5" speaker in the sound bars. I've even fit some of the larger ones without trouble also. But depth is the biggest thing to keep an eye on selecting speakers. Measure yours, I've found the sound bars to very slightly up to 1/2" in depth difference. They probably used a different stamp or something at one time. Just pop a speaker out and measure from the shortest point to the lip of the metal. (a small strait-edge might be helpful)
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Unread 11-30-2004, 06:34 PM   #9
moush
hey guys could you tell me if these will fit my Jeep??
http://www.crutchfield.com/S-ao9NOmD...0&I=1084625CFP
and
http://www.crutchfield.com/S-ao9NOmD...=400&I=108525I
I think these two speakers seem real good and have a decent amount of power handling. I will be buying the adapter bracket and wiring harness for the front speakers and for the sound bar i will be buying the wiring harness. I may also buy some foam baffles to help with bass. Tell me what you guys think and if these will fit. Thanks
Unread 11-30-2004, 08:40 PM   #10
BigWaylon
tubework is cool...
BigWaylon's Avatar
well...the first ones are 4x6 plates...
which goes against the entire discussion of using the adapter brackets and putting 5.25" speakers in the front...
why buy the wiring harnesses...just buy a pack of female spade terminals and wire directly to the speakers...
Greg
Unread 12-01-2004, 11:01 AM   #11
moush
well i dont kno why i need wiring harness the guy from crutchfield said i would need them
Unread 12-01-2004, 11:11 AM   #12
LBX2G
naw if u wire ur spekers backwards by accident u will be fine. But u might notice and audible difference.
LBX2G is offline   Reply With Quote
Unread 12-01-2004, 11:17 AM   #13
SirGCal
SirGCal's Avatar
No you don't need the harness. Crutchfield usually includes them for free though so no big deal but I wouldn't pay for them.
If you wired one speaker out of phase with another (one speaker pos/neg backwards), what will happen is a serious noise cancelation. You will lose all low and high frequencies and it will sound like an old radio, strong in the middle frequencies, hollow, and without feeling. It's pretty noticable. This will not damaget he speakers or stereo in any way, it just sounds like crap.
In an extreme situation only; To check polarity of an unknown wiring setup; you can use a 9 volt battery. Connect it to the speaker (just the factory speaker which you will throw away afterward.) When the speaker pushes out of the front (instead of sucking into the basket), the polarity of the speaker is the same as the battery terminals. It's an old school method but it works. From there you can tell which wires were connected to which terminal and figure out the neg/pos connections.
Unread 12-01-2004, 12:01 PM   #14
BigWaylon
tubework is cool...
BigWaylon's Avatar
if you're buying the speakers from Crutchfield, the'll be included for free, and will be an easier install...
but if you shop around and find the same speakers for less (like Ebay), then don't worry about paying for the harnesses...
Greg
Unread 12-01-2004, 12:08 PM   #15
gmbtj
I have pics in my sig of my alpine sps-170's
Gun Metal Blue Jeep Club Member #1
Low Output 4 Cylinder Jeep Club Member #1 (President)
1999 Four Banga Wrangla - NO MORE!!!! -Going in 4.6L Stroker - TF 727 - Dana 300 HD
Teraflex 3T w/ OME's on 32" BFG M/T's
AtoZ Yaffy Style rocker guards l Tuffy Series II Security Console l Zirgo "S-Blade" electric fan l PSC Trail corners w/ LED's l Hella 500's l Expensive Sound System
gmbtj is offline   Reply With Quote
