HELP!! no spark - JeepForum.com
post #1 of 11 Old 07-06-2009, 05:42 PM Thread Starter
blackhawk099
1976 CJ5
HELP!! no spark
so my 76 cj with the 258 isnt creating a spark, i know the ignition coil is good. help on solenoid wiring and distributor tells etc would be very helpful as the electrical is not my strong suit. i know im gettin good fuel, and good air, so there can't be too too many other problems right? any good walk throughs tests would be a great help
blackhawk099 is offline
post #2 of 11 Old 07-06-2009, 07:23 PM Thread Starter
blackhawk099
1976 CJ5
mainly the wiring
post #3 of 11 Old 07-06-2009, 07:40 PM
mylt1
mylt1's Avatar
got power going to the coil?
mylt1 is offline
post #4 of 11 Old 07-06-2009, 09:28 PM Thread Starter
blackhawk099
1976 CJ5
coil good, distributor cap good, spark plug wires good, all circuits appear to be working properly, could it be the electric control unit?
post #5 of 11 Old 07-06-2009, 09:49 PM
mylt1
mylt1's Avatar
DO YOU HAVE POWER AT THE COIL? just because its good does not mean its getting power. if it were and you have fuel going in then it should start. start with where you have power and go from there.
mylt1 is offline
post #6 of 11 Old 07-07-2009, 02:02 PM Thread Starter
blackhawk099
1976 CJ5
yes there is power at the positive side of the coil, not entirely sure about the negative side tho
post #7 of 11 Old 07-07-2009, 02:09 PM
mylt1
mylt1's Avatar
if you have power to the coil and the coil test good then do you have an ignition control module? it will either be in the dis cap or there abouts. they go bad and can cause the same issue. i know nothing about the older dis's on jeeps.
mylt1 is offline
post #8 of 11 Old 07-07-2009, 03:15 PM
tlendt
If its a Prestolite distributor and you're not worried about originality this might be a good time to go with an HEI or other "one wire" distributor. Easy to hook up, simple to troubleshoot. Might be worth a search. Good luck.
tlendt is offline
post #9 of 11 Old 07-07-2009, 05:57 PM Thread Starter
blackhawk099
1976 CJ5
tested the negative, returned with a result that the ignition module needed replacement, now the engine is firing only when i let the key off the ignition and not maintaining, could this be solenoid wiring now?
post #10 of 11 Old 07-07-2009, 06:08 PM
FmrVette
FmrVette's Avatar
2008 XK Commander
Does it have a ballast resistor? If memory serves it does...and they are infamous for creating a "runs while the key is held, stops when the key is released".
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels. - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline
post #11 of 11 Old 07-07-2009, 06:19 PM Thread Starter
blackhawk099
1976 CJ5
no, it has resisting wiring, and it only seems to start firing after the key is let off, but wont stay on
Need Spark !!! jeepwin Engines & Drivetrain 8 11-29-2009 12:37 PM
Need Spark!! jeepwin Audio, CB & Ham Radios, GPS, & Electrical 5 11-25-2009 08:19 PM
No Spark beano Engines & Drivetrain 0 03-30-2008 06:31 PM
No Spark 75cj5mpi Engines & Drivetrain 1 02-14-2008 06:20 PM
no spark?? 80cj5 Audio, CB & Ham Radios, GPS, & Electrical 5 12-25-2007 11:43 AM
