Help with lights - JeepForum.com
post #1 of 6 Old 03-26-2005, 08:02 AM Thread Starter
Wild Buckin'
Help with lights
I'm almost done wiring my new fogs and the only other wire that i have is supposed to go to ACC ON. To bad i don't know what that is. Please tell me what it is and where to find it.
1999 Tj - Black - Sport
2" Rancho SL - 32"x11.5" Bridgestone MT's - Offroad lights
Black Jeep Club member #96
Wild Buckin' is offline
post #2 of 6 Old 03-26-2005, 08:12 AM
SirGCal
RIP
SirGCal's Avatar
ACC is the vehicular term for accessory power or a wire that is 12V only when the key is turned on. You don't have to use this for the switch but it's nice. If you run it strait to the battery though, be sure to fuse it if it isn't already (3-5A fuse should be plenty). Your main power from the battery should also have a fuse also (probably 30A or so).
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 6 Old 03-26-2005, 08:17 AM Thread Starter
Wild Buckin'
so if i did want to use it, i would put it straight to the battery? If i didn't, than would it drain juice from thw battery?
post #4 of 6 Old 03-26-2005, 08:21 AM
SirGCal
RIP
SirGCal's Avatar
You said your wiring lights right? The correct way to wire lights is like this:
You have a main power that goes from the battery to the lights using the relay to turn on and you have the ACC (or other 12V source) for the switch to control the relay. If the system is turned off, nothing will draw power from anything... If your wiring kit with your lights did not come with a relay, I would suggest you get one to fit this diagram. Any automotive store will usually have them for just a few $.
SirGCal is offline
post #5 of 6 Old 03-26-2005, 08:33 AM Thread Starter
Wild Buckin'
this is all how i set it up except for in the picture it doesn't have anything hooked up to the yellow wire. That is my problem. Do you think i should hook it straight up to the battery or will it blow?
post #6 of 6 Old 03-26-2005, 02:38 PM
SirGCal
RIP
SirGCal's Avatar
You can run it strait to the battery. Just add a 5A fuse to the end at the battery. Then your lights will work when ever you want. Or you an connect to a switch 12V in the cab. Either one. (some people connect it to the wire which turns 12V when the parking lights come on.)
SirGCal is offline
dash lights, tail lights, parking lights stopped working, whats the deal? bortz1892 Audio, CB & Ham Radios, GPS, & Electrical 13 02-26-2011 12:28 AM
LiteDOTS acting strange. Reverse lights coming on very dim with running lights. Kenbo-Slice Audio, CB & Ham Radios, GPS, & Electrical 15 11-16-2010 06:45 PM
Interior lights & door warning red lights stay on all the time f1bash Audio, CB & Ham Radios, GPS, & Electrical 2 08-28-2009 02:40 AM
Rock lights into foot lights;door pins ninemili22TJ Audio, CB & Ham Radios, GPS, & Electrical 3 02-02-2009 03:45 PM
Brake Lights, Tail Lights, Rear Signals. Not Working Properly scmtzc Audio, CB & Ham Radios, GPS, & Electrical 1 12-20-2008 03:45 PM
