HELP led light bar wired to factory foglight harness comes on and goes back off - JeepForum.com
post #1 of 6 Old 01-18-2014, 03:31 PM Thread Starter
foxracing92
I installed a blue light 21.5 inch led bar on my jeep jk wired it to the factory fog light plug when I turn it on it comes on for a second then cuts back off stays off for about 3 seconds then does the same thing again how can I fix this
foxracing92 is offline
post #2 of 6 Old 01-18-2014, 05:36 PM
Indy
Indy's Avatar
Wire it direct to the battery and see if it still does it.
I'm the only gay eskimo.
Indy is offline
post #3 of 6 Old 01-18-2014, 05:45 PM Thread Starter
foxracing92
I did that it it works fine it just does it through the fog light harness
post #4 of 6 Old 01-18-2014, 11:37 PM
Indy
Indy's Avatar
Then its the circuit breaker tripping. The led should be drawing a lot less amps than factory fogs so either its bad or there is something screwy in the wiring. You could always wire fresh through a relay and use the factory wiring to switch the relay.
Indy is offline
post #5 of 6 Old 01-19-2014, 05:48 AM Thread Starter
foxracing92
Ok I put a voltage meter on it with the light on it it's starts at 12 volts then when the light cuts off the voltage goes down to3 volts then after a couple seconds the volts go back up to 12 volts the light comes on then goes back off and back to 3 volts and keeps repeating
post #6 of 6 Old 01-19-2014, 09:14 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
As suggested, use the stock factory wiring to operate a relay and wiring that you install for LED light.
CJ7-Tim is offline
