HELP - DEAD TJ - Electrical Problem - JeepForum.com
post #1 of 5 Old 02-14-2011, 11:14 AM Thread Starter
tglime
Well I really did it this time. This winter my windshield wipers kept blowing fuses. This was happening during a week of blizzards here in MN, so as you can guess wipers were essential. One night after working I needed the wipers to work and I was out of spare fuses so I used a small wire and completed the circuit in the wiper fuse compartment. Worked perfectly and sparingly. The next morning I had to run a few errands and forgot about my rigging and put on the wipers. Within a minute the fuse blew and I smelled singed plastic/wire coating. After that, the Jeep was dead. The cluster would not light up. No noises made when turning the key. However the door open bing bing bing works fine.
I replaced and checked to the best of my knowledge all the fuses and relays behind the glove box and under the hood.
The Jeep is the most reliable thing in my life and I need her back.
I hope someone here can help
Thank you in advance.
tglime is offline
post #2 of 5 Old 02-14-2011, 01:54 PM
Rubicon_Rob04
Your problem is going to be in the same place it was before, providing everything else was fused properly. You may have added to the problem by introducing heat to a wire bundle and shorting more wires but it most likey is going to be somewhere near your wiper circuitry.
Rubicon_Rob04 is offline
post #3 of 5 Old 02-14-2011, 09:35 PM Thread Starter
tglime
Great feedback. I will check out the wire bundles as far as I can and re-check all the fuses again.
Everything was previously fused properly. Ive owned her for 10 years now and no problems until recently.
tglime is offline
post #4 of 5 Old 02-15-2011, 08:17 AM
Richd1963
Richd1963's Avatar
Dude, I hate to say it. But If the Jeep is the most reliable thing in your life. You had better do something about that.
Eeeek! Stay away from my electrical system.
It sounds like you fried some other wires now too. Unscrew the fuse box from the firewall and inspect wiring closely. Look for melted wires. I would advise to disconnect battery before you do anything. It doesn't sound good. Good luck.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #5 of 5 Old 02-15-2011, 10:45 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
A couple of your comments seem contradictory and confusing however, the purpose of a fuse is to protect wiring from current above the rated capacity. I would guess that without the protection of the fuse, something else failed due to overcurrent and is now preventing power flow. The last vehicle I rewired had a couple of wires with in-line fuseable links feeding the fuse panel. Not sure about your specific vehicle but if it's wired similarly, you could have a burnt link. Otherwise, then it's likely a burnt wire or connection.
***Chris***
chris87xj is online now
electrical issue , electrical problem , electrical system , electronic , electronic ignition
serious electrical problem JLanni1218 Audio, CB & Ham Radios, GPS, & Electrical 4 12-06-2010 10:33 PM
61 Willys CJ5 Electrical Dead wapeloquin Audio, CB & Ham Radios, GPS, & Electrical 2 09-06-2010 07:02 AM
electrical problem.... ryan4291 Audio, CB & Ham Radios, GPS, & Electrical 11 05-14-2008 06:57 PM
Is my Optima Red top dead, or problem with dual battery setup, or something else? trayson Audio, CB & Ham Radios, GPS, & Electrical 7 07-06-2005 10:11 PM
Electrical problem Guy Engines & Drivetrain 2 09-05-2001 09:13 PM
