Help ??? Battery drains without key in ??? - JeepForum.com
post #1 of 5 Old 04-24-2012, 09:38 AM Thread Starter
rkcitymuse
1995 XJ Cherokee
Any ideas ?? I have a 95 Jeep Grand Cherokee 4wd. It has an intermittent electrical problem. On occasion it wont start and has to be jumped with another vehicle. Putting a meter on the battery shows it being drained .. Without the ignition key in. If I disconnect the battery it goes back up to 12volts. After it is jumped it will "usually" continue to start up but sometimes just goes dead again. The battery has been checked and holds a charge. When it is running it runs great. I have checked all the fuses and none are blown. Only other elec problems are .. one dead door lock and back hatch light is intermittent. Anyone have any clues ?? I have to find the solution to this. Everytime I think I have it fixed it does it all over again. ????
rkcitymuse is offline
post #2 of 5 Old 04-24-2012, 09:38 PM
SnowdogMarc
Have you put an amp meter in line with the battery to see what the current draw is? All vehicles have a small draw with the stereo and a few other electronics.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #3 of 5 Old 04-25-2012, 01:41 AM
lauderdalechad
2006 WK
Is there going to be an introduction with this post or are u gonna just use us like a dirty one night stand?
Get a test light/volt meter and start pulling relays. Any aftermarket electronics? Check if under hood light stays on(if there is one)
2000 jeep wrangler sport: 31" BFG ATS, auto - wrecked
1997 jeep grand cherokee: stock - gf's zj
2000 Silverado 5.3l Z71- sold
2006 Overland HEMI QDII
lauderdalechad is offline
post #4 of 5 Old 04-25-2012, 04:38 AM
jeepcicle
Make sure to check the battery cables as well, pull them off and clean them if they are corroded. I have a wrangler but had to have my vehicle jumped a few times I thought it was an interior light issue, but turned out to be a poor connection between the terminals and the cable.
jeepcicle is offline
post #5 of 5 Old 04-27-2012, 01:22 AM
jeepcreek
It's Homeless Harry. I had the same problem - a few mechanics checked it out, tried to "fix" the problem - no solution. Given I leave my Jeep open, I suspect that Homeless Harry sleeps in my Jeep at night - and given he's afraid of the dark, leaves the door ajar - the interior light serving to keep him safe from the bogeyman.
Anyway, my main mechanic is a no-nonsense kinda guy - so he offered me two solutions - both involving a battery disconnect. You can buy a cheap one that attaches to the battery (the route I took), or they can install it inside the Jeep.
Luckily for me, Homeless Harry is a crackhead and can't figure out how to re-connect the battery, so he's moved on to another Jeep. Possibly yours?
At any rate, it works. No clue what's causing it, and I kinda don't care anymore. But my no-nonsense mechanic did relate that it wasn't fouling anything else up. Best of luck.
jeepcreek is offline
battery , electrical problem , short
Jump starting a vehicle from your second battery via a dual battery kit tbevans Audio, CB & Ham Radios, GPS, & Electrical 3 07-04-2011 04:05 PM
New cd player drains battery even when its off TellicoTJ Audio, CB & Ham Radios, GPS, & Electrical 4 01-30-2011 10:24 PM
Battery question. drains rapidly - tests good - need lights - plz help ahuf Audio, CB & Ham Radios, GPS, & Electrical 9 09-15-2010 10:21 PM
Herculining Interior w Drains bmyohn Technical Articles & Write-Ups 5 03-31-2010 10:18 AM
dual battery or single heavy duty battery for camping? yosemitejeep Audio, CB & Ham Radios, GPS, & Electrical 23 11-07-2009 12:05 AM
