Help. asd relay problem - JeepForum.com
post #1 of 2 Old 05-15-2013, 02:06 PM Thread Starter
Deaconblu
1995 XJ Cherokee
Hello, i have a 95 Grand Cherokee that electricly is acting crazy. lott of intermintment problems. very suspishous ecm is bad. My question, when i pull the asd relay there is 12 volts at three of relay inputs with switch on. the bottom slot, one closest to front of car has 8 volts. Is this normal?? Should all four relay inputs have voltage??
thanks for any help/
dnelsonrocks@yahoo.com
Deaconblu is offline
post #2 of 2 Old 05-18-2013, 07:24 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
With the ignition in the ON position you should have 12V at 2 of the ASD relay pin sockets in the PDC and ground on the third one (which comes from the ECM). The third pin gets voltage through the ASD relay. Keep in mind a relay is nothing more than a heavy duty switch. The relay needs power and round to close the circuit that goes through it to run a specific device(s).
Check the second ground wire that goes from the firewall to the engine block it is may be NG.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
