Hella Lights Help - JeepForum.com
post #1 of 7 Old 07-12-2012, 09:26 AM Thread Starter
acurrier2012
Hella Lights Help
I bought some Hella Lights for my 01 Cherokee.
Not too "Electrically Smart"
Anybody want to post a good vid/pic or step by step instructions?
That would be great, Thanks!
acurrier2012 is offline
post #2 of 7 Old 07-12-2012, 09:29 AM
ShakaBrahTJ
I've seen some pretty descent videos on YouTube on how to install these off road lights. The ones I saw were for Wranglers, but they were pretty descriptive and should be good enough to walk you through yours.
ShakaBrahTJ is offline
post #3 of 7 Old 07-12-2012, 09:59 AM
Xpress
Wiring isn't hard, not hardly at all. It seems confusing at first because there's a lot to take in, but once you have a basic grasp of what is happening then it gets easier and easier to figure out.
Follow that basic diagram. If your lights didn't include a relay, I highly suggest investing into a few relays, Amazon has a 5 pack for dirt cheap:
http://www.amazon.com/AGT-Relay-Harn...e+5+pack+relay
I've bought them, they work exactly as a relay should. From there it's very straightforward if you follow the wiring diagram.
All about that unibody life.
Xpress is offline
post #4 of 7 Old 07-12-2012, 10:05 AM Thread Starter
acurrier2012
That will definitly be a help. Thanks Guys.
If anybody happens to see a cherokee wiring video, please post.
Thanks.
post #5 of 7 Old 07-12-2012, 01:29 PM
ShakaBrahTJ
Hey Xpress, I recently purchased some off-road lights and did not include a relay. They are only 55w per light (2 lights). I have seen several videos about putting in a relay. What's your opinion on putting in a relay and what exactly does a relay do? Does it reduce power through the switch? Thanks
post #6 of 7 Old 07-12-2012, 02:45 PM
jpittman
A relay acts as a trigger to turn on lights (or anything electrical) that draws a lot of current. The switch is not carrying the load of the lights.
A relay simply allows you to use a small amount of current to switch a much larger load. If you have lights that draw a lot of current you don't really want to have to run large wires under the dash and use a large switch.
jpittman is offline
post #7 of 7 Old 07-12-2012, 03:28 PM
ShakaBrahTJ
Thanks. I will consider getting a relay then.
cherokee , electrical , hella , instructions , lighting
Fog Lights: KC or Hella? WJL Audio, CB & Ham Radios, GPS, & Electrical 23 10-22-2010 06:41 PM
Hella lights don't ship with Hella relays...Hella crazy! kpauley General Jeep & Off-Road Equipment 1 09-02-2009 07:32 PM
hella lights connor0770 Audio, CB & Ham Radios, GPS, & Electrical 1 04-21-2009 10:40 PM
Best Hella lights for the $$ NYSLC93 General Jeep & Off-Road Equipment 2 11-28-2008 09:19 PM
Hella 500 lights ugrider21 Audio, CB & Ham Radios, GPS, & Electrical 1 11-04-2004 04:30 PM
