Hell Yeah you can put 6.5" speakers in the rear speaker pods! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Hell Yeah you can put 6.5" speakers in the rear speaker pods!
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-09-2009, 03:28 PM   #1
jake1977
I know this has been done but, I did this today and it was a PITA. I used a wiring diagram from a 2003 Jeep FSM to identify the polarity of the wiring in both pods. The diagram showed Br/Lb wire as a negative and Br/Yl wire positive for the left pod. The right pod showed Bk/Pk wire as a negative and Db/Wt wire as positive. When I opened both sides the wires were all Br/Yl and Br/Lb. So I went off of the left pod wiring from the schematic. I have a 2004 Tj. Can anyone confirm that is right? Thanks to all who help.
jake1977 is offline   Reply With Quote
Unread 08-09-2009, 06:56 PM   #2
reeln77
i just used my multimeter on voltage when you have it set up correctly i have a negative bar on the side showing ground when i had it backwards i had no bar
reeln77 is offline   Reply With Quote
Unread 11-05-2011, 11:45 AM   #3
unlimitedlj
I have an 05 and mine is blue/brown and yellow/brown on both sound pods and after talking to my tech buddy he pulled the fish and it showed the yellow/brown as positive and the blue/brown as negative at least 05 and 06 models but, I'm sure it would apply to all 2003-2006 Jeep wrangler being its the same set up.
unlimitedlj is offline   Reply With Quote
