heater fan doesn't work - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > heater fan doesn't work
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
Unread 12-03-2013, 02:02 PM   #1
marcosmmmark
I have a 2000 Cherokee.my heater fan stoped so I thought proly the blower and bypassed the switch with a straight wire and blower motor still works. So, being on a tight budget, to the salvage yard I go and come back with a switch assembly. Changed it and the same thing, it doesn't work. Any suggestions would be appreciated
marcosmmmark is offline   Reply With Quote Quick reply to this message
Unread 12-03-2013, 02:10 PM   #2
Ploseph
I am new to the forum and do not know much about cars. I had the same issue in my 2000 WJ Limited. I had to replace the resistor which powers the blower motor and its located right behind the glove compartment. I purchased mine right down the street at Advance Auto Parts for $155.00!!! I soon as I put the new one in the air started working immediatley. It could also just be a connector. I would run some tests to see whats getting power and whats not. Thats what I did before spending the money.
Ploseph is offline   Reply With Quote Quick reply to this message
Unread 12-03-2013, 03:43 PM   #3
marcosmmmark
Thank you that is rather expensive I'll do the test first as you suggested
Unread 12-03-2013, 08:32 PM   #4
Bmel17
usually if the resistor goes it's because on the blower motor fins are worn and spinning too fast. If you replace the blower it will blow the new resistor in a short while. I just replaced both a few months ago as my fan only worked on high~
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline   Reply With Quote Quick reply to this message
Unread 12-05-2013, 07:54 PM   #5
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The climate control fan system consists of the fan itself, a blower motor resistor, wires, a relay, and the switch.
Physically inspect them all, looking for and smelling for any melted or damaged components. Resistor failure is rather common, and may or may not be a sign of other issues. Probably 80% of the time a fresh resistor will cure any fan problems.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
