Headlights cut out. 92 XJ - JeepForum.com
post #1 of 4 Old 08-10-2013, 06:57 PM Thread Starter
djlambert
I upgraded my headlights to the globes that fit in place of the 6054 with a 9003 bulb in them. Ever since the upgrade my headlights cut in and out after about 5 min of driving. I disconnected one and the other will then stay on. Is there a relay that is getting hot and cutting out. Any ideas where to go next?
djlambert is offline
post #2 of 4 Old 08-10-2013, 11:02 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yes, you are overloading the stock relays and wires. The headlight switch itself is also prone to failure.
Buy or build and upgraded headlight wire harness. The PutCo H4/9003 wire harness is a decent low cost wire harness. Other companies make better quality wire harnesses that cost a bit more.
CJ7-Tim is offline
post #3 of 4 Old 08-12-2013, 08:22 PM Thread Starter
djlambert
Do you know where the relay is located? I have a haynes repair book and it doesn't give location and the wiring diagram is hard to understand.
post #4 of 4 Old 08-13-2013, 05:23 PM
CJ7-Tim
CJ7-Tim's Avatar
The headlight relay should be in the fuse box under the hood. You need an upgraded headlight wire harness.
CJ7-Tim is offline
