Headlight issues.. - JeepForum.com
post #1 of 17 Old 01-09-2012, 07:42 PM Thread Starter
jherrington
Headlight issues..
I recently had gauge cluster issues, and a dead battery. The lights worked, and so did the brights. I guess I pulled too hard on the light switch and boop, out came the switch into my hand I cant seem to get it in to where it catches. and yes i pushed the little button on the top of the switch.
I just replaced the battery, and now even the brights don't work... I don't have a clue to what happened... thank you for helping.
jherrington is offline
post #2 of 17 Old 01-11-2012, 04:33 PM
krutj
2009 JK Wrangler
Need more info to help.....
-- Joel --
krutj is offline
post #3 of 17 Old 01-11-2012, 10:25 PM
JPNinPA
JHERRINGTON'S JEEP
User Has Not Filled Out Jeep Information
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #4 of 17 Old 01-11-2012, 11:33 PM Thread Starter
jherrington
It's a 97 jeep wrangler.. What else do you need?
post #5 of 17 Old 01-12-2012, 06:30 AM
krutj
2009 JK Wrangler
Start by checking all your fuses and relays.
-- Joel --
krutj is offline
post #6 of 17 Old 01-12-2012, 11:05 AM Thread Starter
jherrington
I checked my fuses and the ones under the hood. Can a relay go out? How can you tell? And does anyone have a link to show which relay and fuse is for under the hood?
post #7 of 17 Old 01-12-2012, 12:12 PM
krutj
2009 JK Wrangler
Most likely a bad relay will make a buzzing noise. You may want to ask for help in the TJ tech forum to find which relays, should be two, one for high beam, one for low beam. Is there a diagram on the underside of the fuse box lid?
-- Joel --
krutj is offline
post #8 of 17 Old 01-12-2012, 05:46 PM Thread Starter
jherrington
Yes, but nothing that says headlights. Lol
post #9 of 17 Old 01-12-2012, 05:49 PM Thread Starter
jherrington
I've got the fuel pump, one that says IOD one that says store, an abs sys, for some reason, missing the horn relay, got the ac and asd. Then te big ones, and pump(don't have) aux fan, starter.
post #10 of 17 Old 01-12-2012, 06:05 PM Thread Starter
jherrington
I'm starting to think it has something to do with me accidentally pulling the headlight switch out of the switch itself..
post #11 of 17 Old 01-13-2012, 06:02 AM
krutj
2009 JK Wrangler
That could be it for sure, did you find the headlight relays?
-- Joel --
krutj is offline
post #12 of 17 Old 01-13-2012, 07:06 AM Thread Starter
jherrington
No. I don't think there are any
post #13 of 17 Old 01-13-2012, 08:59 AM
krutj
2009 JK Wrangler
There has to be relays, it's the way the headlights fire.
-- Joel --
krutj is offline
post #14 of 17 Old 01-13-2012, 12:32 PM Thread Starter
jherrington
I'm going to replace the switch. Because I was poking around with it, and if I got it in the right spot, the lights would turn on, and I could turn the brights on from there. But when I pulled the brights "switch" for the quick brights feature, the lights went out... But if I pushed it into the lock position, they would come on
post #15 of 17 Old 01-13-2012, 04:59 PM
krutj
2009 JK Wrangler
That's good that you found the problem, just remember, there are relays for the headlights, it's the only way that they operate....next time, be more gentle...lol
-- Joel --
krutj is offline
Headlight Issues... PLEASE HELP bearzah Audio, CB & Ham Radios, GPS, & Electrical 2 12-27-2011 10:09 AM
Headlight help!! Taylorettel Audio, CB & Ham Radios, GPS, & Electrical 6 07-08-2011 08:30 AM
KC HiLITES Slim Jeep Headlight issues question Giggidi Audio, CB & Ham Radios, GPS, & Electrical 0 09-24-2010 11:34 PM
Headlight/HID help! Raabguy Audio, CB & Ham Radios, GPS, & Electrical 7 01-16-2010 11:02 AM
Headlight Issues arctic jeep Audio, CB & Ham Radios, GPS, & Electrical 3 11-13-2005 01:38 AM
