Headlight help!! - JeepForum.com
post #1 of 7 Old 06-25-2011, 02:01 PM Thread Starter
Taylorettel
1980 CJ7
Headlight help!!
Alright so my headlights no longer work after an arc jumped from the hood to my head in the rain while charging the battery. All the other lights work so I dont think its the switch. What is the possibility of both bulbs blowing at the same time? is there a fusable link somewhere in the line? Help a brotha out JF!
Taylorettel is offline
post #2 of 7 Old 06-25-2011, 07:04 PM
liftedon37s
If you have a multimeter check to see if you have power to the switch first.
It has some things done to it.
liftedon37s is offline
post #3 of 7 Old 06-26-2011, 10:54 AM
JPNinPA
Check the fuse yet?
Ouch! Arc from the hood to the head...Could others see the lights?
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #4 of 7 Old 06-26-2011, 11:57 AM Thread Starter
Taylorettel
1980 CJ7
How would I go about checking the switch with a MM?
There actually isnt a fuse for the headlamps , but a 24 amp circut breaker in the switch. I replaced the switch yesterday with one I had laying around and the headlights still didnt turn on. I must have blown both lights when I shorted it out. My new Delta hyper whites are on their way !
post #5 of 7 Old 06-29-2011, 05:28 PM Thread Starter
Taylorettel
1980 CJ7
Alright so whoever is with me on this one, lights are not here yet but i have another question. Should i run a relay in-line with the new Deltas?
post #6 of 7 Old 06-29-2011, 07:00 PM
JPNinPA
Absolutely! What wattage are the bulbs?? Be sure to run heavy enough gauge wire for the length you are running or you lights will not be as bright and you will avoid other issues later on.
JPNinPA is offline
post #7 of 7 Old 07-08-2011, 08:30 AM Thread Starter
Taylorettel
1980 CJ7
well, Installed the new lights and they still dont come on. any ideas?
cj , headlights problem
cj help,headlight jezwald101 Audio, CB & Ham Radios, GPS, & Electrical 0 06-19-2011 07:54 AM
Headlight/HID help! Raabguy General Jeep & Off-Road Equipment 2 01-17-2010 07:27 AM
Headlight/HID help! Raabguy Audio, CB & Ham Radios, GPS, & Electrical 7 01-16-2010 11:02 AM
xj headlight ? backwoodz Audio, CB & Ham Radios, GPS, & Electrical 8 09-04-2009 04:21 PM
New Headlight help DYOLLNAVE Audio, CB & Ham Radios, GPS, & Electrical 12 04-11-2008 10:55 PM
