> General Technical Discussions
> Electrical, Audio, GPS, & 2-Way Radio
headlight conversion help
08-29-2007, 10:28 AM
#1
Northman
I may have broken a policy here. In most pages posting the same question in two different forums is not accepted. it was not done intentionally. I just recognized this section. If a moderator sees this.. please cancel the post in TJ and t/y. I posted in TJ something similiar. The lock ring that secures the headlights will not secure tightly on after market lights namely the Delta Tech h-4 conversion. There is upwards of 1/8 in. slop. any ideas .. either to shim it up.. safely, or maybe the other Quad bar Xenon? Thanks
SWEAT
Uncle Willy, The InnKeeper #3
06 Rubicon locked and loaded....
08-29-2007, 11:46 AM
#2
Are you sure the screws aren't stripped? Did you try putting a stock light back in just to verify (doesn't take but a second...) Maybe it's the wrong aftermarket light... You'd have to check that with the manufacturer... Also, only a few H4 conversions are street legal... FYI.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
08-29-2007, 12:41 PM
#3
Northman
thank you so much for the straightforward reply. Yes I did check and there may be a possibility the lense is not the right one for the 06 Rubi. Going to research it today. I also called Quadratec and the response was pretty close the same. I was considering a new retaining ring.. but then again, I should not have to, these lights are an OEM replacement and should ( key word) bolt right in.. so to speak. Then I also found out that since the Jeep is an 06 .. too new.. the ring hasn't been put into stock. Next thought was the Delta 4 bar with that black plastic ring.. maybe it increases that snug fit.. but what is the light dispersion? I know that the lense is fluted but with what pattern? I don't know if I would like it. I am aware of the DOT issues ,thanks for the mention, some wouldn't be that considerate. So I'm kind of vexxed. any ideas are going to be appreciated. thanks again
Dan
08-29-2007, 02:39 PM
#4
Are you refering to the less expensive Delta H4 conversion? I have this setup on my 04, and it installed flawlessly without slop. I can't really offer more help at this moment, but those lights should work in your Jeep.
08-29-2007, 05:07 PM
#5
Northman
Ok.. so now, I will have to confirm that I DID get the right conversion kit. The 06 had a little too much play for my liking so it may have been for another model. Thank you
| Suggested Threads |
- Headlight conversion or not? - Electrical, Audio, GPS, & 2-Way Radio (14 replies)
- Automatic Headlight Conversion? - Electrical, Audio, GPS, & 2-Way Radio (3 replies)
- headlight conversion? - Fabrication Shop (15 replies)
- Best H4 headlight conversion? - Electrical, Audio, GPS, & 2-Way Radio (6 replies)
- H4 Headlight Conversion Kit - Electrical, Audio, GPS, & 2-Way Radio (16 replies)
