Having issues with wiring up lights - JeepForum.com
post #1 of 9 Old 10-27-2013, 12:39 AM Thread Starter
ek5soccer
I am new to this, but took my factory fog lights and re wired them to a toggle switch. Since I was new I found and copied the wiring digram for KC lights. Have a 30amp switch with earth, load, supply. 40amp relay with 30, 85,86, 87 and 87a. with a pre made wire harness that goes to the relay. also 30 amp inline fuse. I pigtailed my lights together. grounds to ground then grounded them on the bolt next to my headlight ground. ran the pos. to pos then back to the 87 pos. i have a pos from 30 to the inline fuse then to the battery positive. 86 is ground and 85 is run to my switch which in by my driver side speaker. ran that ground to the speaker ground. (havent found a 12v source to tap into yet.) Ive pretty much ran into a brick wall, any advice or help would be much appreciated.
So any ideas about how to get my lights to turn on would be great. Also where/how i could get my 12v source for my switch.
ek5soccer is offline
post #2 of 9 Old 10-27-2013, 09:23 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Don't use 87a. When the relay is energized. 87a is turned from ON to OFF and at the same time 87 is turn ON. Power both lamps from 87.
Use the body for a dedicated ground, don't use a speaker wire. Any 12 volt circuit that is switched on/off with the ignition key will work for the light switch connection.
CJ7-Tim is offline
post #3 of 9 Old 10-27-2013, 11:25 AM Thread Starter
ek5soccer
Originally Posted by CJ7-Tim
Don't use 87a. When the relay is energized. 87a is turned from ON to OFF and at the same time 87 is turn ON. Power both lamps from 87. Use the body for a dedicated ground, don't use a speaker wire. Any 12 volt circuit that is switched on/off with the ignition key will work for the light switch connection.
Yea I'm not using 87a but do I need to do anything with that wire to close the circuit? I'm using the body where the speaker is ground. But how do i find one of those 12v source
post #4 of 9 Old 10-27-2013, 07:31 PM
CJ7-Tim
CJ7-Tim's Avatar
87a doesn't need to be connected. If there is a wire lead on the relay socket, simply tape up the bare wire end.
Probe for 12 volts with the key on and off. A 12 volt bulbs and some wires will work, but a volts/ohms multi-meter is easier to use and will come in handy for all sorts of testing/repairs.
CJ7-Tim is offline
post #5 of 9 Old 10-27-2013, 08:00 PM Thread Starter
ek5soccer
87a doesn't need to be connected. If there is a wire lead on the relay socket, simply tape up the bare wire end. Probe for 12 volts with the key on and off. A 12 volt bulbs and some wires will work, but a volts/ohms multi-meter is easier to use and will come in handy for all sorts of testing/repairs.
Yeah got it figured out, now just need to decide how I want to pull my 12v switch power from. Any thoughts?
post #6 of 9 Old 10-27-2013, 08:03 PM
CJ7-Tim
CJ7-Tim's Avatar
Any circuit will work. I would tap into the dash/console light wires. Near the 4x4 shifter should be easy to access. Then the fogs will only work (stay on) when the headlight switch is on.
CJ7-Tim is offline
post #7 of 9 Old 10-27-2013, 08:06 PM
sbcranger
cig. lighter, radio are two common easy points to pick up 12v for a switch to trigger a relay.
sbcranger is offline
post #8 of 9 Old 10-27-2013, 08:57 PM Thread Starter
ek5soccer
Yeah thats what ive been picking up on, I havent looked back there yet, but ive looked under the steering wheel there are a lot of wires. This being my first time I want to feel confident on what I do, so any instructions would be very helpful.
post #9 of 9 Old 10-28-2013, 10:48 AM
sbcranger
Easiest way to identify a wire is to use a wire schematic for your year and model. They will show you where they come from and go to as well as color. If you don't want to do that disassemble the dash to get to the back of cig lighter and splice in a wire off of the color wire on the cig lighter. Your library should have access to online manuals where you can find your wiring schematics for your vehicle.
light , switch , wiring
