Grounding Point - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Grounding Point
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 02-11-2010, 02:59 PM   #1
mhogan55
Grounding Point
I am about to install an aftermarket amp in the back of my 06 Grand Cherokee. I have already run power, RCAs, and remote wire, but I need a good place to ground this amp. I think my options are to remove the container thing in the rear that holds the jack and flip up storage panel, or to try and ground to a bolt under the rear seats. Does anyone have any thoughts on what might be the easier route to take here? Maybe even a different option? Before anyone asks, I did a search but found no information on anything newer than a 99. Thanks for your time and input.
mhogan55 is offline   Reply With Quote
Unread 02-11-2010, 03:01 PM   #2
Jeeeeepster
I ran my ground to the bolt on the bottom of my rear seat and it works perfect.
Jeeeeepster is offline   Reply With Quote
Unread 02-11-2010, 04:38 PM   #3
02gixxersix
Seat bolts are usually a good option but still test it with a multimeter. Also I would pull the bolt out and get a wire brush on a drill or a piece of sandpaper and make sure you get a nice clean metal on metal connection. Many times these parts are painted and you might get a ground but not a good one. In my WJ I drilled a hole in the tub where the spare tire mounted, sanded it down, and bolted the ground wire to that.
Black 2000 TJ Sport - NV3550 - 30/44 w/ 3.73s - Currie Currectlink Steering - 35" ATs (for now) - 2003 engine and tranny swap - XRC8 - Homebrew Winch Plate - Uniden Pro520XL - Electric Fan - Lock-right in front
(not installed)
02gixxersix is offline   Reply With Quote
