Grand Cherokee air/heat won't turn off. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > Grand Cherokee air/heat won't turn off.
Cold Air Intake and Throttle Body Spacer KitKrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-15-2013, 04:05 PM   #1
Tayjust07
I have a 2007 jeep grand cherokee Laredo, and it doesn't matter if you have it set to heat air or anywhere inbetween when you turn the fan knob off on the far left the force goes down but after a while you will notice it's still on. (It doesn't just come back on I just noticed it when my hand/feet where getting really cold.) Has anyone else had this happen, and tryed to fix it? Or any ideas on what could be causing it? Thanks for any feedback!
Tayjust07 is offline   Reply With Quote Quick reply to this message
Unread 12-17-2013, 09:45 AM   #2
Tayjust07
Anyone else have this happen? Or is it normal and I just didn't notice it before? Could it be that for whatever reason the truck is going to "vent" and is just letting thru as I drive?
Unread 04-26-2014, 01:58 PM   #3
kkotvas26
2007 WK
Same problem with 2007 JGC
I also have a '07 grand cherokee with the same issue. I didn't notice the problem until I went on a long trip through the mountains during the winter. I was constantly turning the heat on and off and would notice that it never fully turned off. It can get really uncomfortable in the cabin. The whole thing drives me crazy some days. I've only had this truck since October 2013. Anyone else with this problem know how to fix it?
kkotvas26 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2014, 03:13 PM   #4
SnowdogMarc
Ok dumb question but my dad has an 04 Grand and maybe they changed it since then but....Left is fan control, Center is temp and the Right is what vents it comes out of AND the master off switch when fully counter clockwise.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote Quick reply to this message
Unread 04-27-2014, 12:12 PM   #5
kkotvas26
2007 WK
2007 has the same basic set up. It wouldn't be so much of a problem if the actual vents would close fully even if the air was still coming in the vents could stop them if they were made like wrangler jk vents or 2011+ JGC vents.
ac , heat , help please
