good places to run grounds + put relays for lights - JeepForum.com
post #1 of 4 Old 12-10-2006, 08:57 PM Thread Starter
jrodum
Lightbulb good places to run grounds + put relays for lights
i was wondering where are some good places to run the ground for the foglights and the best place to put the relay.
01 TJ, 5.3L LM4 4l60e lokar shifter, np241C with JB conversions SYE, Carolina Driveline F+R driveshafts, taurus fan + griffin radiator, 33" Destinations, D30 ballistic brackets + 8.8 + MAD brackets, SOLID diffs, 3.5" RE lift discos + CAs ,1" BL, magnaflow muffler Panasonic reciever, Infinity speakers / Tweeters, 2 Rockford Fosgate 8's, Herc'd grill and tub, LOD rockers, Hella fogs, LOD front shorty bumper w/custom tube, Rear Bumper/ Tire Carrier + LOD frame tie-in bracket, Warn xd9000i
jrodum is offline
post #2 of 4 Old 12-11-2006, 12:06 AM
Los
I got tired of looking for screws to ground my many ground leads so I brought in battery power and battery ground into the cab. I used 10ga. cable and hooked up the power to a fuse block. I put a ring terminal on the ground and used an existing screw to ground it to the cab.
You could probably ground to most screws in the cab, but I wanted a good clean ground back to the battery. BTW if you bring power into the cab, you'll want to fuse it as close as you can to the battery using the appropriate fuse rating for that wire/cable.
'04 TJ, RE 4.5, 33 BFG MT's, ARB F/R, LoD F/R, D30, S35
Los is offline
post #3 of 4 Old 12-11-2006, 08:29 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Running a separate circuit to the cab for all of the connections is a good idea for all of your in cab connections but there is no need to run your light ground wires back there.
Some where next to the battery install a ground stud, you should be able to find one at the local automotive store; run all of your ground wire to this point.
You will need to have two wire to each of your lights, if no ground wire is there you need to add one to the housing or ground point inside the light.
This method reduces bad ground connections due to rusting and corrosion.
Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #4 of 4 Old 12-11-2006, 08:04 PM Thread Starter
jrodum
thanks guys. anyone got pics of setup under the hood?
jrodum is offline
Good tire places online? jlax2485 Tires & Wheels 3 01-25-2010 02:57 PM
Running lights without relays!!! Willys '05 Audio, CB & Ham Radios, GPS, & Electrical 8 01-26-2009 09:43 PM
Best places for Hella off road lights?? Yesfan70 Audio, CB & Ham Radios, GPS, & Electrical 4 04-07-2008 03:22 PM
good relays? Walton99 Audio, CB & Ham Radios, GPS, & Electrical 4 11-05-2004 10:35 AM
?? Switches and Relays for a TJ?? Trying to mount lights Joezilla General Jeep & Off-Road Equipment 1 12-17-2003 03:45 PM
