Fuse Block Empty spaces - JeepForum.com
post #1 of 8 Old 05-08-2008, 02:14 PM Thread Starter
pachary
OK,
I've got an 05 unlimited. There are a few empty spaces in the fuse block. If I use these circuits for accessories instead of tapping other wires, will I find wires on the back side of the fuse block or what?
I am assuming that these spots will be "live" (switched or constant). I can't believe that differently optioned jeeps would have different fuse blocks.
So, what's back there? Unused wires or places to plug in terminal connectors?
Thanks
Paul
2005 TJ Unlimited/I6-M6/Rubi 4:1 Tcase/4.5RESF/1.25JKS BL-1BMML/37"SSRs/WarnM8000/Besttop TireCarrier/Waggy D44/ FR-RR DetroitD44/Cobra Remote CB/custom F&R Bumpers/JeeperMan Skids/York OBA/Rokmen TummyTuck/TNT 3" Fenders and Rear Corners/AA SYE- Carolina Drivelines CV Shaft
pachary is offline
post #2 of 8 Old 05-08-2008, 08:20 PM
kencaz
It's unlikely they would put wiring in the empty slots of the fuse panel. If you do see empty slots with spade connectors already there, you could easily test for voltage. Even if you have a source voltage, switched or un-switched, you'll have to install the fuse and run the load side wiring behind the fuse block.
Remember, too, that the fuse block has a maximum amperage as well and tapping off that for to many accessories could blow a main fuse for the block.
Good Luck
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #3 of 8 Old 05-08-2008, 08:41 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
you'd probably be better off getting a sPOD and wiring up a fresh box
My builds:
and
or follow us on
spyder6 is offline
post #4 of 8 Old 05-09-2008, 05:29 AM Thread Starter
pachary
I was figuring I could use it this for stuff like:
Winch Relay activation, OBA clutch operation, CB, and garage door opening power supply.
These don't take much amperage at all and I know at least one of those slots is for rear defrost. That is a 30 Amp or so circuit that would easily handle all of these at once. But I would like to use a couple of the slots for this project.
Thanks
Paul
pachary is offline
post #5 of 8 Old 05-09-2008, 07:44 AM
mylt1
mylt1's Avatar
hit up your local boating supply store and get an aux fuse panel. much easier and faster.
mylt1 is offline
post #6 of 8 Old 05-09-2008, 11:30 AM
SirGCal
SirGCal's Avatar
Thanks
Paul
You would definitely not want to use it for a CB even if it was a safe load. Simply due to the noise. CBs I always run directly to the battery for both power and ground (one of the few devices I also run the ground). Proper fuse on the power obviously.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #7 of 8 Old 05-10-2009, 06:58 AM
Richd1963
Richd1963's Avatar
Hey, I just bought one on ebay for 19.99 + 5.00 shipping and the price is good compared to full retail.
http://motors.shop.ebay.com/merchant...rmrsZ1QQ_fromZ
I am sure they won't last at this price! Good luck!
Richard
Richd1963 is offline
post #8 of 8 Old 06-20-2009, 03:22 PM
DanZ51
I'm searching for the same info. I don't need a whole new panel just to run a clean circuit for my XM radio. The factory fuse panel on my '04 Rubicon has hot side connectors (unused circuits) in the fuse panel. But there is no connector on the load side of the panel; just a vacant spot. I need to know exactly what type of connector Jeep is using. Looks like a Pico 1598D or a Pico 5806 GM Pak Con connector.
http://store.qualitydist.net/pipate.html
My local NAPA failed me on this one. I may just mail order and pay the shipping.
DanZ51 is offline
Fuse block rustywrangler Audio, CB & Ham Radios, GPS, & Electrical 13 05-10-2009 06:52 AM
wiring a fuse into the existing fuse block... can it be done? CAPCDT388 Audio, CB & Ham Radios, GPS, & Electrical 1 11-14-2008 01:07 AM
Can you use the empty slots on the fuse panel for added equipment? Rubi Unlimited Audio, CB & Ham Radios, GPS, & Electrical 2 07-31-2007 11:55 AM
fuse block in cab?? jays-tj Audio, CB & Ham Radios, GPS, & Electrical 2 03-08-2007 08:31 AM
2nd fuse block ? tattooos0080 Audio, CB & Ham Radios, GPS, & Electrical 8 08-22-2005 10:04 AM
