Quantcast Front YJ Speaker replacement - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Front YJ Speaker replacement
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 06-10-2001, 11:09 PM   #1
bluebellyday
I need to replace the front speakers in my 95Yj What is the speaker size and who makes a good quality replacement speaker?
I have Alpine in my sound bar and in the rear I would like to stay with them if I can.
How much of a pain are they to get out?
bluebellyday is offline   Reply With Quote
Old 06-11-2001, 06:20 AM   #2
jeffy
They are 4x6". They aren't too difficult to remove but takes some disassembly. I took my dash apart to install the speakers the first time around. You can get away with just pulling the dash out as one piece. 4 bolts on each side, next to the speakers. Drop the windshield and then there are some more torx bolts under there, remove those and then the dash should be able to be pulled out enough to get back behind the dash.
I currently have some Rockford Fosgate's. These are my second set of speakers so I've taken the dash apart a couple times.
www.4BangerJP.com
A Pitiful RigRater Score: 789RRv1.0
jeffy is offline   Reply With Quote
Old 08-22-2001, 02:07 PM   #3
Matt Graham
Hey man, I've gotta better idea if you don't want to take the dash off, because at the stereo shop I work at, we don't remove the dash to install the 4x6's. If the factory speakers are already removed this will work, just slide the speaker up there and onto the mounting studs. If you have access to some 8 GA. wire, strip off about a 1/2". This insulation will slide onto the mounting studs and mount the speaker securely. We have been doing it this way for years and have never had any problems with the wire insulation no holding securely.
(The drivers side is alittle more difficult than the passenger side, but it can be done.
For Sale: Catch-All rear floor liner for YJ (charcoal in color) - $25
Matt Graham is offline   Reply With Quote
Old 08-26-2001, 11:02 PM   #4
I-4
a simple project turned into a 2 day group grope fest the mb quarts i bought where not the same "bolt" pattern as the stock speakers. they were put on 2 of the posts and held in place with those little nuts off of the stock ones.i was finally able,after lots of profanity,able to get enough of my dash aprt to be able to "reach" in.not a pretty sight.
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline   Reply With Quote
Old 09-26-2001, 06:03 PM   #5
Willis91YJ
blue belly,
Of course you want alpines... they are the best! They make the alpine SPS 4629P I believe is the model number and don't forget the last P or you will regret it. There is a big difference between 4629 and 4629P's and it's not worth the discount in sound quality to get the cheaper ones! Good Luck man and if you need any help drop me a line
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline   Reply With Quote
Old 08-10-2009, 03:59 PM   #6
Aarzak
Hey guys Im planning on doing the same for my 4.0 YJ 1991, I want to install Pioneer speakers 4x6 but a friend of mine told me that is not necessary to remove the whole dash, he said I could actually intall the speakers from underneath.
What do you guys think? any advice? Is that really true?
Thanks in advance
"take prudent risks!" (emphasis on prudent)!
-Aarzak
Aarzak is offline   Reply With Quote
Old 08-10-2009, 05:52 PM   #7
92yjwrangler
Go alpine or pioneer...2nd on the installation...but it takes patience...buy from crutchfield and the give you new mounting brackets and wiring harnesses free!
92 wrangler yj 33in Dunlop Mud Tires
pioneer head unit and front speakers sony amp with 2 rear 6x9 alpine pro series speakers
92yjwrangler is offline   Reply With Quote
Old 08-22-2009, 02:20 PM   #8
Aarzak
Ok... I tried and i give up...
I manage to remove the front [asenger speaker from underneat BUT, trying to remove the drivers front speakers from underneat is a *****. I give up.
Can any one tell me how? please help
-Aarzak
Old 09-27-2009, 08:20 PM   #9
plac
bump, i need ideas too. my speakers from 1993 are turning to powder and dust.
2011 VW GTI DSG 4DR
2009 Nissan Xterra 4x4
plac is offline   Reply With Quote
Old 09-28-2009, 09:23 AM   #10
gily25
that e-brake can get in the way...that's why I went with the centrapod...here is a link tot he full instructions where you fold the windshield frame down...you can replace the seal while you have it all apart...as these YJs love to leak when the seal gets dry.
http://www.carstereohelp.com/stereoremovalJeepWranglerFSpk1.htm
Select Increments 91970 - Select Increments Centra-Pod Speaker Enclosure for 76-95 Jeep® CJ-5, CJ-7, CJ-8 Scrambler & Wrangler YJ - Quadratec
gily25 is offline   Reply With Quote
Old 09-28-2009, 09:43 AM   #11
plac
thanks!! that removal link is killer!
2011 VW GTI DSG 4DR
Old 01-20-2010, 10:30 PM   #12
SuperGlueHero
Going through my Haynes manual and I stumbled across the speaker removal section. It says to just remove the passenger side by reaching up there and unbolting it. For the driver's side it says to unbolt the parking brake assembly by removing the two nuts that protrude into the engine bay and then one that attaches it to the dash. Once that is out of the way you can probably do it the same way. I agree that folding the windshield down makes it easier, but if you're a little gun-shy to attempt that you can try this method.
2012 JKU - Crush - Stock for now
91 YJ - Blue
SuperGlueHero is offline   Reply With Quote
Old 01-22-2010, 08:44 AM   #13
parkerm26
arite ive read through several of these threads about how to do this. i have the windshield down and the 5 torx under it unbolted from the chasis and the dash will only move up about an inch it wont pull out. there is something else holding it in but i cant see wat it is. anyone know wast im missing? i followed all the steps
93' YJ 5in w/33's. Narrowed front 60 in progress of rebuilding, 14bolt in progress of rebuilding. End Result= 8in w/ 38s
parkerm26 is offline   Reply With Quote
Old 01-27-2010, 11:16 AM   #14
parkerm26
anyway.. figured it out. not hard just time consuming
Old 02-02-2010, 09:16 AM   #15
Aarzak
Hey guys, can anybody tell me where can I get the torx screws that holds the windshield? they are pretty rusty and since now I know how to replace the front speakers (thanks gily25) I wanna get if possible, stainless steel replacement screws. Thanks!
-Aarzak
Glock Forum
