Front door locks in my 2000 XJ are stuck. - JeepForum.com
post #1 of 7 Old 11-29-2013, 06:16 PM Thread Starter
Thompy79
I put an aftermarket CD player in my 2000 XJ, and the install went well, everything works fine. After I was done I realized that my front passenger and driver door locks are stuck in the locked position but the door is not locked and won't lock. Any help is greatly appreciated.
Thompy79 is offline
post #2 of 7 Old 11-29-2013, 06:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Did you take the door trim panels off ?
CJ7-Tim is offline
post #3 of 7 Old 11-29-2013, 07:04 PM Thread Starter
Thompy79
Yes, I also installed new door speakers as well. They work fine as well.
Thompy79 is offline
post #4 of 7 Old 11-29-2013, 07:19 PM
CJ7-Tim
CJ7-Tim's Avatar
Then I would suppose that you incorrectly re-assembled the lock rods, accidentally bent them, or they are somehow jammed up in the plastic door liner sheet.
CJ7-Tim is offline
post #5 of 7 Old 11-29-2013, 08:18 PM Thread Starter
Thompy79
What should I do next, obviously I need to take the door panel back off, but then what? Thank you for your responses.
Thompy79 is offline
post #6 of 7 Old 11-30-2013, 09:00 AM
CJ7-Tim
CJ7-Tim's Avatar
Ideally you would compare your door internals to another door that functions correctly. All I can suggest is that you study how all the mechanisms function and see if you can logically determine the problem. I would guess that the rods that connect to the door handle and lock switch on the plastic door panel are the main cause of the problem.
CJ7-Tim is offline
post #7 of 7 Old 11-30-2013, 11:08 AM
Bmel17
same thing happened to me in a past install on one of my cars. Like CJ7-Tim said, take it back apart and see if you can figure it out. I had just placed one thing slightly wrong and it was an easy spot. good luck!
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
