Ford Taurus Fan - JeepForum.com
post #1 of 5 Old 02-10-2014, 06:52 PM Thread Starter
vortec85cj
Ford Taurus Fan
I have this fan installed into my jeep cj7. I purchased delta DCC control relays for it, http://dccontrol.com/2sp.pdf . My questions come with the fuse size for the battery wire and ignition wire. I'm not sure of the amp draw on startup and continuous draw. Most searches I've done have come up with mixed reviews. My next question involved adding an on/off toggle. Can I just splice into the battery wire? Does it need a fuse of its own?
vortec85cj is offline
post #2 of 5 Old 02-12-2014, 06:13 AM
bgredjeep
1987 YJ Wrangler
That controller looks similar to the Hayden 2sp controller I used to run. I personally didn't trust it to directly power the fan so I just used it to switch a second set of 150amp relays I had from a previous setup.
If this one works the same way, it also runs both high and low at the same time when the 2nd speed activates. This works, but it isn't as fast and only high speed. To resolve this I added another SPDT relay that switched the low speed off when high was activated. It was a bit complicated, but it worked great untill I changed to the Volvo setup.
bgredjeep is offline
post #3 of 5 Old 02-27-2014, 08:03 AM
turbogus
1978 CJ5
On 'BB' I ran independant switches, relays and fuses so with a SPDT master switch I could override the low speed function of the fans in an overheat situation. I'm running the Merc Mystique (Ford Contour) setup.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #4 of 5 Old 03-03-2014, 09:03 PM
willis36
willis36's Avatar
That controller is made specifically for the Taurus fan and can handle everything that fan can throw at it with no problem without additional relays. It also has independent low and high circuits. The hayden controllers I have seen/used have all been complete junk. The dc controls variable controller is where it at if you don't mind spending the extra money. No relays and can handle any fan out there.
willis36 is offline
post #5 of 5 Old 03-04-2014, 07:33 AM
turbogus
1978 CJ5
I don't know if these are the 'junk' controllers you're mentioning but I repurposed the one on the left that's been in constant service for over five years now. It may not be as elegant as more expensive options but these are doing alright by me.
Of course one man's toilet may be another's toilet bowl.
turbogus is offline
