Fog Lights? - JeepForum.com
post #1 of 5 Old 09-25-2004, 10:22 PM Thread Starter
rockon1202
rockon1202's Avatar
Question Fog Lights?
I want to get a set of bumper-mounted fog lights for my SE but don't know what to look for or what to get. Should I go with the OEM lights or is there something by Hella, KC, etc that you all recommend? Thanks!!
rockon1202 is offline
post #2 of 5 Old 09-26-2004, 09:00 AM
JeepKidd
Sorry for cutting in, but if I can add on to that question....
Will the switches fit in the precut holes? Some switches look alot bigger then what is already there.
Hurricane Jeep Club Member # 4
Under 18 Jeep Club Member # 5
Green Jeep Club Member # 127
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Hella 500 Driving Lighs
2 Delta Fog Lights
JeepKidd is offline
post #3 of 5 Old 09-26-2004, 10:08 AM
SirGCal
SirGCal's Avatar
It all depends on what you want. If you want off-road only lighting, then you can get anything on the market and good aftermarket lights will easily put factory fogs to shame. However, if you want to drive with them on the street, you have to check your local regulations for what you can and can't do. Every area is different. Here, I can run aftermarket lights up to a certain power, other places you might not even be able to run factory fogs unless it's foggy. You just have to check.
As for the light switch, you can buy factory switches but they are expensive. To put aftermarket switches where the factory one's go might require careful switch selection as I'm sure not all switches are going to fit.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #4 of 5 Old 09-26-2004, 05:15 PM Thread Starter
rockon1202
rockon1202's Avatar
I'd probably just buy a factory switch off eBay cheap. As far as lights, I wouldn't want something that would light up the entire forest, but something that would still provide good illumination. I'm not going to bother worrying about local regs, I'm in the army and will be moving every few years and won't know the regs for where I'll be living next. I'll probably go with something for just off road, but like I said, it doesn't need to light up the night. Any recommendations?
post #5 of 5 Old 09-26-2004, 07:16 PM
SirGCal
SirGCal's Avatar
In that case, just get what ever lights you prefer. All brands have good and bad points. (In General) KC's and some Hellas are a little cheaper while providing good light. PIAAs are usually more expensive and some people will argue their quality over others. HID's are the best but also cost a small fortune. (KC and Lightforce have some nice HID options though if you can afford it...)
If you just want good, effective lighting when you need it, I would probably just pick up some good ProComp lights in the size and power you want and wire them up yourself. They have great entry-level lights for a great price and some higher-end models as well.
SirGCal is offline
dash lights, tail lights, parking lights stopped working, whats the deal? bortz1892 Audio, CB & Ham Radios, GPS, & Electrical 13 02-26-2011 12:28 AM
LiteDOTS acting strange. Reverse lights coming on very dim with running lights. Kenbo-Slice Audio, CB & Ham Radios, GPS, & Electrical 15 11-16-2010 06:45 PM
Interior lights & door warning red lights stay on all the time f1bash Audio, CB & Ham Radios, GPS, & Electrical 2 08-28-2009 02:40 AM
Rock lights into foot lights;door pins ninemili22TJ Audio, CB & Ham Radios, GPS, & Electrical 3 02-02-2009 03:45 PM
Brake Lights, Tail Lights, Rear Signals. Not Working Properly scmtzc Audio, CB & Ham Radios, GPS, & Electrical 1 12-20-2008 03:45 PM
