Quantcast fog light relay - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > fog light relay
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 11-20-2009, 04:56 PM   #1
wickerham
fog light relay
where's the fog light relay that makes them turn off when the high beams are activated? I read a write-up someplace where you could bend the one contact over to prevent them from turning off during high beam mode. I have a 93 ZJ with factory fogs. this is for offroad use, btw.
also I'd like if fogs would turn on as soon as parking lights are turned on, for twilight running.
wickerham is offline   Reply With Quote
Old 11-21-2009, 08:20 AM   #2
SirGCal
SirGCal's Avatar
you'd need an FSM to find out or simply do some hunting. Even in the TJ, different years put them in different spots. But check around the two fuse locations first.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Glock Forum
