Few audio questions - JeepForum.com
post #1 of 4 Old 01-17-2007, 01:39 PM Thread Starter
NY JeeP
Tj Few audio questions
I just got the 9856 alpine deck with the ipod cable. From my understanding it connects from the back of the unit. Where have you guys ran the wire to(to connect into the ipod) I've heard of the glove box, just would like to get feedback for ideas.
Also, biggest speakers for soundbar in 98 sahara would be 5.25 or 6.5 w/o modification?
I'm gonna make brackets for the front to fit the 5.25 speakers. Still up in the air about throwing in a sub. If I do I'm leaning towards putting it in the rear seat. Feedback on that would be great if anyone has done it.
Lastly any good speakers out there that doesn't require an amp? Obviously anything is better than stock at this point. Thanks in advance
NY JeeP is offline
post #2 of 4 Old 01-17-2007, 02:34 PM
PJL
1) I ran my mp3 player wire down behind the glove box and then fed the wire underneath the edge of the center console. I keep the player in a cup holder.
2) Yes, many 6.5s will fit without modification. The only problem you may run into is mounting depth.
3) Check out www.sirgcal.com He built a 2 sub box and a 3 sub box in the back seats of 2 different Jeeps. I don't run a sub myself, but I've heard from many around here that a down-firing sub is the best way to go in a Jeep.
4) If you don't want to go with an amp, get the lowest RMS wattage speakers you can, but don't expect an appreciable improvement over stock. I ran Alpine S series 5 1/4" speakers for a time with no amp, and now I'm running them and Alpine R series 6 1/2" with a 4x40 watt amp. It'll also help your sound if you stuff the soundbar with 100% polyester pillow stuffing or some other type of polyfil.
PJL is offline
post #3 of 4 Old 01-17-2007, 03:18 PM
bheiser
bheiser's Avatar
2006 KJ Liberty
Tj
Originally Posted by NY JeeP
I just got the 9856 alpine deck with the ipod cable. From my understanding it connects from the back of the unit. Where have you guys ran the wire to(to connect into the ipod) I've heard of the glove box, just would like to get feedback for ideas...
I recently installed the 9857 with the iPod cable. The HU is installed in the Tuffy overhead console. I have an iPod Nano which I have in a protective rubbery case.
My original thinking was that I'd put velcro on the back of the iPod case, and stick it to the side of the overhead console. However I haven't found a cement that will actually stick to the rubbery iPod case to hold the velcro!!!
Also, I realized in practical use, it'd be a pain to have to constantly unplug and move the iPod every time I park (to avoid theft). So my current thinking is (when I have time to take apart the overhead console) I'll re-route the cable through the inside of the console, and find a way to sit the iPod inside the console - probably on top of the HU. That way, it can stay attached when I park, and will be locked up along with the HU
I guess if you have a Tuffy glove box, that'd work well too.
bheiser is offline
post #4 of 4 Old 01-17-2007, 03:37 PM
mylt1
mylt1's Avatar
35w rms max is what you want there are some 30w rms speakers out there but you have to look. they WILL make a vast improvement over the stock setup. again watch your rms numbers and you should be fine. i would stick with 5.25's all the way around just so you can keep the numbers inline with everything.
mylt1 is offline
Audio questions bays2112 Audio, CB & Ham Radios, GPS, & Electrical 0 06-17-2009 10:58 PM
Questions about TJ factory audio Kow Audio, CB & Ham Radios, GPS, & Electrical 2 01-26-2007 05:26 PM
Audio Questions TheWombaT Audio, CB & Ham Radios, GPS, & Electrical 7 06-15-2006 05:32 PM
Audio Questions belmor Audio, CB & Ham Radios, GPS, & Electrical 12 04-05-2004 10:28 AM
Audio mod questions Minus6 Audio, CB & Ham Radios, GPS, & Electrical 1 10-13-2002 07:22 AM
