Quantcast factory subwoofer replacement... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > factory subwoofer replacement...
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-29-2007, 12:19 AM   #1
omgsideburns
Does anyone have a suggestion for a speaker to replace the factory subwoofer in the center console?
Mine was blown when i purchased my jeep and I pulled it out and reglued the surround but it's come apart again.
I was just gonna replace it with a 6.5 inch speaker from any autoparts store but it's a dual voice coil and i wasn't sure how to wire it up since all the cheapos i've seen are single.
omgsideburns is offline   Reply With Quote
Old 07-29-2007, 12:40 AM   #2
Humboldt
Better off to search in the electrical/audio Forum (THis is going to get moved there anyway)
heres a link for ya.
Humboldt is offline   Reply With Quote
Old 07-29-2007, 12:54 AM   #3
BYuen
Wahoowa
BYuen's Avatar
I'd find a compatible 8" sub and do some trimming of the stock console. I'm pretty sure it works well someone did tell me about it.
White 01 TJ Sport 4.0 NV3550
BYuen is offline   Reply With Quote
Old 07-29-2007, 01:44 AM   #4
akell215
I put in a JL 6W0 and a JL A1200 amp on it and love it. The only thing that I had to do was use a die grinder and cut out the plastic inside the factory enclosure. The JL is a good bit deeper than the stock speaker but after trimming out the box it fit fine. If you go this route I would suggest putting some spacers on the top screws that hold the speaker in so the console will be pushed away from the sub. I didn't at first but once the sub surround "broke in" the speaker would hit the console at the top and rattle. It sounds much better than I was expecting and It doesn't take up any extra space except for where the amp is and I just put it under the rear seat.
akell215 is offline   Reply With Quote
Old 07-29-2007, 11:38 AM   #5
Toolshed
I installed the JL 6WO in mine also. Had to grind out space for the larger magnet and use an amp. You can buy a new enclosure for 299.00. (I think) Pretty expensive for a paper woofer but much easier to deal with and no amp to install.
Toolshed is offline   Reply With Quote
Old 07-29-2007, 02:09 PM   #6
omgsideburns
yeah i was trying to avoid using a new amp. thanks for tips guys.
Old 07-29-2007, 02:24 PM   #7
Toolshed
here's one.
http://www.jeepsareus.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=JAU&Product_Co de=LI2&Category_Code=Wrangler2
Old 07-29-2007, 02:47 PM   #8
spyder6
Just violated my Parole
spyder6's Avatar
that says 8" though, i thought the factory was 6"?
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 07-29-2007, 03:04 PM   #9
Toolshed
Hmm, it sure does. You're right though, factory size is 6 or 6.5 or something like that. If i had to do it all over again, I think I would just get that enclosure with the sub and psudo amp included. I hate having to worry about my amp when my top is off.
Old 01-23-2012, 02:46 PM   #10
Airbourne32603
Factory subwoofer replacement
This looks promising.
http://www.quadratec.com/products/14133_1001.htm
Airbourne32603 is offline   Reply With Quote
Old 01-23-2012, 02:50 PM   #11
Doty152
Lepercons are green.
Doty152's Avatar
I got so much money, when the bank sends me statements, they use red ink and put a dash before the amount.
Alcohol may be mans worst enemy, but the Bible says to love your enemy.
Doty152 is online now   Reply With Quote
Glock Forum
