#1 | |
Factory sub - aftermarket HU
ok so dont laugh...
i recently installed a wire harness for my interior dash, only one problem, it was not equip with sub woofer wire connections. i know, im an idiot.... ![]() anyways, my question is... is there a way to connect the factory subwoofer wires directly to the rca sub preout in the back of the HU? if yes, please explain if no, ![]() oh, the head unit is a sony CDX-GT300 thanks again!
#2 | |
No, there is not. And there is no stupid questions... only stupid answers.
The factory sub uses the speaker-outputs from the head unit to get it's source signal and the factory-harness power antenna wire (so use the Sony's remote-turn-on wire to go to that instead of the Sony's power antenna wire; if it is so equipped, If the Sony only has a PA wire, then use that). There are ways to go from high-level to low-level (speakers to RCAs) but not the other way around. That's basically what the amp does is convert the low-level to a high-level signal.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
