Factory Sub - JeepForum.com
post #1 of 5 Old 08-12-2001, 03:41 AM Thread Starter
mybluejeep
Question Factory Sub
I have a 2001 TJ with the factory sub. I want to install a new CD receiver. I have not opened up the dash yet to look at the wiring. How is the sub wired to the receiver? Do I have to find a specific type of output on the receiver, or will most suffice?
Any suggestions would be greatly appreciated.
mybluejeep is offline
post #2 of 5 Old 09-28-2001, 08:41 AM
bcompton
bcompton's Avatar
Post
I have the same setup. I haven't opened it up, but if you will notice, the sub is only active when you are faded to the rear speakers. My guess is that the sub has a crossover in it because of the above and because the sub is an option, but the receiver is the same with our without it.
So, I would bet that the receiver is a pretty basic 4-speaker output.
Let me know if you can confirm or refute this...
01 Sport, front drum brake & birfield joint conversion, custom '4 Wheel Drive' stickers, neon washer nozzles, chrome type 'r' oil pan bolts, wooden bead seat pads, racing exhaust tip, offroad license plate frame,
lots of misc. stuff (2.5" Skyjacker springs, 1" BL, 1"MML, Custom flat tcase & engine skid, RE arms, Skyjacker shocks, JKS Discos, Superlift Trac bars, Garvin bumpers, Warn 9.5ti, Lockright & trac-lock, 32" BFG KM's, Kilby & warn skids, EOR rocker bars, cowl snorkel)
bcompton is offline
post #3 of 5 Old 10-20-2001, 01:53 PM
TJSahara
Post
Did you ever get a new head unit installed. I am having trouble with mine. I could use your help mybluejeep.
01 XJ Sport - 3" OME, trXus MT
TJSahara is offline
post #4 of 5 Old 10-20-2001, 02:58 PM
mytjnamedrex
Post
get the kit from crutchfield. I installed a pioneer on a friends jeep and he hasd the sub. I simply spliced into the factory wiring as it says in the instructions and it worked fine. The only thing is that you need to set up everything when you get the new HU in (treble/bass/fade). good luck
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #5 of 5 Old 10-21-2001, 01:38 PM
TJSahara
Post
He has the 2001 center counsle factory sub? I have been looking at the pioneer 4300. What did he go with? Was the volume loud when you turn the key? Thanks for the help. What kit from crutchfield? the wiring harness
TJSahara is offline
Factory sub box Wif Audio, CB & Ham Radios, GPS, & Electrical 9 03-19-2008 05:35 PM
'07 factory DVD Killian Audio, CB & Ham Radios, GPS, & Electrical 1 12-10-2006 06:39 AM
Factory HU AUX help Frost9501 Audio, CB & Ham Radios, GPS, & Electrical 1 10-16-2005 09:59 PM
How do I upgrade factory fog light wiring and still use my factory switch??? 01SolarYellowTJ Audio, CB & Ham Radios, GPS, & Electrical 7 05-02-2005 06:43 PM
'01 TJ Factory Sub TJSahara Audio, CB & Ham Radios, GPS, & Electrical 2 01-26-2002 05:37 PM
