Fabbing a switch panel - JeepForum.com
post #1 of 3 Old 03-07-2007, 01:26 PM Thread Starter
jeepster93
jeepster93's Avatar
I made my own 4 toggle- switch panel. This was made to fit my Yj. I will prolly put it down where the ash tray goes, I no longer have an ash tray.
The toggles will run:
-Front spot loghts
-Rear back-up light
-Belt driven air compressor.
-Dual battery management toggle and led.
I have it wired so 2 toggles are simple on/off with on lighting the led. 1 toggle will, front spots, have an on/off with a led switch when high beams are on and the led on the panel will light when on. 1 will have a 3 possition switch and led for the dual batteries.
I will paint it either black or gray to match the interior. i will; post a pic when mounted.
jeepster93 is offline
post #2 of 3 Old 03-08-2007, 05:47 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
looks very sharp!
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #3 of 3 Old 03-08-2007, 07:24 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Good Work.
At least you did it yourself.
When you use the panel, it should give you a feeling of pride that you built your own.
Scrambler82
Do it right the first time !
Scrambler82 is offline
how do I get to the switch panel in my tj bandit455 Audio, CB & Ham Radios, GPS, & Electrical 3 11-30-2008 06:44 AM
My switch panel Comanche_ General Jeep & Off-Road Equipment 0 08-29-2008 12:34 AM
Accessory switch panel MikeBW Audio, CB & Ham Radios, GPS, & Electrical 11 10-26-2006 11:53 PM
Aux switch panel... neZZr Audio, CB & Ham Radios, GPS, & Electrical 21 05-16-2006 01:14 PM
TJ switch panel CETROV Fabrication Shop 1 06-15-2004 03:25 PM
