Every audio problem I can imagine. Need some help.(pics) - JeepForum.com
post #1 of 10 Old 11-12-2009, 06:57 PM Thread Starter
stpeteTJ
Allright, so I'll list the problems by order of importance.
1) The Polk audio 5-1/4 component system I bought indeed came with 5-1/4 speakers, but somehow they're too big for my 5-1/4 speaker bar. I don't know how to fix it other than make the hole bigger, and I don't really know how to make the hole bigger.
Photo:
2) Came with tweeters, even though they're supposed to be 2-way speakers. Where the hell am I gunna put these tweeters? I guess I could make a hole? But I'm not equipped for that either.
Photo:
3) Splitter won't fit in speaker bar. I know I can just put the splitter under the dash and run the wire to the speakers, but from what I was told the further away you put the splitter the less performance you get.
Photo:
4) New head unit's wiring harness doesn't match OEM harness. I was told to cut my OEM harness in half? I don't really understand that. I s'pose I could just we-wire everything?
Photos:
stpeteTJ is offline
post #2 of 10 Old 11-12-2009, 08:12 PM
Reverb
With regards to the plugs - you can get an adapter at your local auto parts store - advance auto or pep boys carry them around here.
As for the rest you're either going to have to return them and get ones that fit or like you say cut the holes bigger. If they are decent speakers I'd be buying a saw about now.
Reverb is offline
post #3 of 10 Old 11-12-2009, 08:21 PM Thread Starter
stpeteTJ
They're pretty nice speakers, and if I sold these I'd just be buying the same thing in a smaller size.
What saw do you figure I could get to make this work? I dunno how to cut a round whole in steel short of a drill. Figure a jig saw with a steel-cutting blade would work?
stpeteTJ is offline
post #4 of 10 Old 11-12-2009, 08:26 PM
XJ Jay
that fact that you dont know what the cross over is called, that there are adapter harness or that a 2way speaker set means a mid woofer and a tweeter, eather in a coaxial or componet forum means your should pay some one to do it, or hit up some car audio sites on the net
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #5 of 10 Old 11-12-2009, 08:28 PM
XJ Jay
jig saw and the steel cutting blade for the win, now figure out the other pieces of the puzzle
XJ Jay is offline
post #6 of 10 Old 11-12-2009, 08:40 PM Thread Starter
stpeteTJ
Very true. I was given the impression that this would be a plug-and-play kinda thing, I would've taken it to a local shop had I known it would be this complicated.
I would now, but now that I'm in the middle of it, I really wanna do it myself. I wouldn't learn anything if I pay someone to do it, and it wouldn't be nearly as satisfying.
Yeah, that's what I'm thinking, I have a sawzall but not a jig saw, I'm gunna go poke around at sears tomorrow.
stpeteTJ is offline
post #7 of 10 Old 11-12-2009, 08:46 PM
mylt1
mylt1's Avatar
any car audio shop or even walmart should have the adapter.it will either have the wiring instructions in the package or on the package. all you do is wire the radios harness to the adapter then its just plug and play. as far as cutting the hole, a sawzall will leave you with nothing but a huge mess and probably screw it up so much that the speakers still wont fit. get a jig saw, its easier to control and will leave a better cut with the correct blade.
mylt1 is offline
post #8 of 10 Old 11-12-2009, 09:17 PM
XJ Jay
yeah dont use the sawzal, get a jig saw. i had to jig saw out my doors to get my 6 1/2 compo set to fit where the factory 5 1/4 was
XJ Jay is offline
post #9 of 10 Old 11-12-2009, 10:25 PM
alexrule123
alexrule123's Avatar
I used a dremel with a cutoff wheel when I fit the 6.5's in my door. By the way, which headunit are you using?
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #10 of 10 Old 11-12-2009, 10:37 PM Thread Starter
stpeteTJ
Allright, I'll go and pick the adapter and a jig saw tomorrow.
Good to know someone else has already done this with good results, thanks!
I have a dremel, but it's an itty bitty cordless one, I don't know that it'd have the power needed.
The head unit I bought is a Fusion CA-IP500
stpeteTJ is offline
97 TJ Audio Build - with link to pics jhh Audio, CB & Ham Radios, GPS, & Electrical 6 03-13-2009 09:39 AM
Jeep Audio problem Afterdawn Audio, CB & Ham Radios, GPS, & Electrical 1 05-15-2007 08:01 AM
TJ audio problem help!! TJ_Firefighter Audio, CB & Ham Radios, GPS, & Electrical 3 02-06-2006 11:53 AM
audio problem wakeboarder 21 Audio, CB & Ham Radios, GPS, & Electrical 2 07-31-2005 07:08 PM
audio pics JSBlu974X4 Audio, CB & Ham Radios, GPS, & Electrical 7 03-23-2003 11:22 AM
