Engine Keeps Dying - JeepForum.com
post #1 of 8 Old 10-08-2013, 02:15 PM Thread Starter
trraleigh
Engine Keeps Dying
I have an 06 TJ Rubicon with about 145K miles on it. It keeps dying after running for about 15 minutes, sometimes more, sometimes it won't go 10 seconds. Runs fine, then loses oil pressure, sputters for a second, then dies. It starts right back up. Dies again. I've already changed out the crank position sensor, cam sensor, and synchronizer. More of the same.
I've been fairly good with the maintenance since I've owned it.
I'm hoping it isn't the computer. Any ideas?
trraleigh is offline
post #2 of 8 Old 10-08-2013, 02:54 PM
Necko2529
Pull the harness plugs out of the computer and check the pins for corrosion. Also, Chevy the ground strap that goes from the valve cover to the firewall right in the middle of it behind the motor.
Good luck.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 8 Old 10-08-2013, 06:20 PM
Holder350
1995 XJ Cherokee
Check the fuel pressure at the rail.
Any check engine light?
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 8 Old 10-08-2013, 07:36 PM
JPNinPA
Check out this thread on ODPA
http://www.jeepforum.com/forum/f9/ch...d-read-963235/
http://www.jeepforum.com/forum/f9/lo...17/index2.html
EDIT: what does it idle at and does the idle go up prior to dying? Any knocking? Leaks at the intake that may open once the engine warms would cause this.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #5 of 8 Old 10-08-2013, 07:54 PM
streetglideok
2005 KJ Liberty
Any codes set? I have seen faulty O2 sensors on the jeeps do this. Usually though its within a few minutes of startup though.
streetglideok is offline
post #6 of 8 Old 10-09-2013, 11:33 PM
super_ringo
Did you index the cam sensor when you replaced it? I'm having startup issues with my 99 wj and I'm coming to the conclusion that my cam sensor needs to be aligned with tdc.
http://www.jeepforum.com/forum/f11/h...ensor-1145301/
super_ringo is offline
post #7 of 8 Old 10-11-2013, 12:45 PM Thread Starter
trraleigh
I will check these at the beginning of next week. All the codes have been corrected, but they show again, after the engine shuts off. There aren't any noises, etc. when the engine shuts off. It just loses power. Then, the faults return.
post #8 of 8 Old 10-11-2013, 09:23 PM
JPNinPA
What codes are you getting?
JPNinPA is offline
