Engine error codes, Is this possible? - JeepForum.com
post #1 of 5 Old 07-06-2008, 10:35 AM Thread Starter
Gr8fulDeadHead
Exclamation Engine error codes, Is this possible?
Hey guys, new to all this, and an upfront thanks for all the info I've already learned just checking out the site. Now, enough brown-nosing and with the real problem......
My Jeep stopped running and wouldn't start. Checked the error codes initially and got:
12-batt disc.
33-A/C clutch relay circuit (It doesn't have A/C though)
51- O2 sensor running lean
14- MAP sensor voltage too low/high
55- End of codes.
I put in a new MAP sensor, and hose. She started and ran like a champ, but after being shut down, will not restart. The next set of error codes was
12-batt disc.
33- a/c clutch relay
13- map sensor vacuum (i had the hose off that time)
17- engine running cold
51- o2 sensor (lean)
14- map sensor electrical
55- end of code.
I replaced the coolant temp sensor and used contact cleaner on the MAP male end, and still no start. But the only codes I get now are:
12- batt sic,
33-a/c clutch relay
55- end of code
Any ideas? Thanks for even reading through all this BS, and hope your having a Gr8 day!
Gr8fulDeadHead is offline
post #2 of 5 Old 07-06-2008, 11:17 AM
03Wrangler
03Wrangler's Avatar
2010
battery disc. is normal...
a/c is also if you dont have it (i believe)
03Wrangler is offline
post #3 of 5 Old 07-06-2008, 12:29 PM Thread Starter
Gr8fulDeadHead
if the a/c code is normal, and i don't have the "engine running cold" at this time, any ideas what could be preventing start? i'm at a total loss... thanks for the response.
post #4 of 5 Old 07-06-2008, 03:21 PM
03Wrangler
03Wrangler's Avatar
2010
does it crank and sound normal?
is there gas in the tank?
post #5 of 5 Old 07-06-2008, 03:57 PM Thread Starter
Gr8fulDeadHead
thanks to all that read this, and especially to those that tried to help. i figured out the problem and will elaborate in the blog section. thanks again to all of you!
Error Codes : P0320 & P0158 MoniqueMenchaca Engines & Drivetrain 1 08-27-2009 11:49 PM
Engine light on, but no codes. 0utback Engines & Drivetrain 4 01-26-2008 03:00 PM
error codes arepee Engines & Drivetrain 0 05-16-2004 01:45 PM
Engine codes Trainer Engines & Drivetrain 2 09-18-2003 01:46 PM
Engine codes Gacherokee Engines & Drivetrain 6 03-07-2002 08:56 AM
