Electrical Wiring Through JK Firewall - JeepForum.com
post #1 of 6 Old 06-14-2010, 04:48 PM Thread Starter
eillirand
2010 JK Wrangler
Where does one run wiring through the JK firewall. I could not find any openings. I read one thread mentioning for auto transmissions use the opening where the clutch but I have a man. transmission so that option is not available.
Is there another place I am missing or do I have to drill my own hole?
2010 JK 4DR Rubicon Manual Transmissions.
Thanks!
eillirand is offline
post #2 of 6 Old 06-15-2010, 08:31 AM
SirGCal
SirGCal's Avatar
Nah, just drill a new hole and use a grommet. It's not difficult. Just be sure both sides are clear and drill slow.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 6 Old 06-15-2010, 11:23 AM
donie
2014 KL Cherokee
FWIW on either side of the dash, there is a removeable plate.
Remove the plate and push a screwdriver thru the foam into the engine compartment.
The right side comes out right by the battery.
Makes it easy to run and connect accessory wiring.
Hope this helps.
14 Cherokee Limited 4x4
73 K7UTA
donie is offline
post #4 of 6 Old 06-28-2010, 02:54 PM
BoomBoom
2010 JK Wrangler
Did the same thing as Donie for my windshield lights this weekend, ran the switch through the driver side hole as explained above, worked out well.
BoomBoom is offline
post #5 of 6 Old 06-28-2010, 03:01 PM Thread Starter
eillirand
2010 JK Wrangler
Yep. Found the foam and got the wiring all done. Thanks.
post #6 of 6 Old 06-05-2013, 02:02 PM
lflr-2012
Hey guys, I took your advice and had no problem getting from the engine compartment and into the cabin on my 2012 Sport S by puncturing the yellow foam. Notice that the last picture is of the clutch master cylinder which in my case being a standard transmission jeep would not allow me to puncture through the rubber seal like you would be able to in an automatic model. My new driving lights work great and it took about 15 minutes to pull the three wire I needed to pass from one side of the firewall to the other. I had a two-conductor set for the switch going to the relay near the battery and power to the switch going from the inside of the vehicle where the switch is and on to my left side front parking light bulb. This way my driving lights can only go on when my parking or regular lights are on so I don't forget to turn them off.
See the attached pictures.
Thanks, lflr-2012
lflr-2012 is offline
In need of some wiring/electrical advice, PLEASE!!?? collegejeeper21 Audio, CB & Ham Radios, GPS, & Electrical 2 03-18-2010 07:49 AM
Electrical Wiring Diagram bradbb2005 Audio, CB & Ham Radios, GPS, & Electrical 1 12-04-2007 01:42 PM
Electrical Gurus.. Aux Lighting Wiring Help mYJ Audio, CB & Ham Radios, GPS, & Electrical 6 01-24-2006 08:04 AM
Wiring through the firewall tarpon57 Audio, CB & Ham Radios, GPS, & Electrical 2 02-09-2005 08:34 AM
Cb wiring (electrical rookie) shmoken875 Audio, CB & Ham Radios, GPS, & Electrical 11 02-08-2005 11:58 AM
