Electrical problems with headlights/radio. Help - JeepForum.com
post #1 of 2 Old 04-11-2009, 09:55 AM Thread Starter
txasylum
1989 FSJ Cherokee
Question Electrical problems with headlights/radio. Help
Here is my problem.
I turn on my headlights. My high beam light is on. If I switch the high beams to off, nothing happens. You can see a very slight dim in the high beam light, but you have to really watch to see this. As for the headlights, the passenger light is on, but I don't think it is as bright as it should be. The driver side is not working. I played with the fuse box last night and I fixed the problem, but it did not last long and I can not duplicate what I did. In addition to this problem, my radio works fine until I turn on the ignition. When I turn on the ignition I get nothing but static. So I don't know if I have a problem with the light switch, the low/high beam switch, the ignition switch, a ground? I have been messing with this for a few hours and haven't gotten anywhere.
Suggestions please!
Oh, it is a 1989 Cherokee XJ.
Thanks
Bob
txasylum is offline
post #2 of 2 Old 04-11-2009, 10:41 AM
SirGCal
RIP
SirGCal's Avatar
you probably are looking at a bad connection. I'd start testing wires, especially around the fuse box where you said that you got it working briefly. That's probably where the malfunction is.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
CB Radio electrical interference Chris_W_2k5 Audio, CB & Ham Radios, GPS, & Electrical 8 11-09-2010 03:35 PM
Electrical Ghost killing radio reception herculz Audio, CB & Ham Radios, GPS, & Electrical 4 01-08-2010 06:42 AM
electrical problem with headlights and cd player VMI Jeeper Audio, CB & Ham Radios, GPS, & Electrical 3 07-03-2007 09:46 PM
Headlights and Radio rwjeep Audio, CB & Ham Radios, GPS, & Electrical 2 04-27-2007 11:05 AM
Electrical - Stereo - Radio has no reception! DoHMaN Audio, CB & Ham Radios, GPS, & Electrical 2 04-10-2006 10:56 PM
