electrical problem with headlights and cd player - JeepForum.com
post #1 of 4 Old 07-01-2007, 09:25 PM Thread Starter
VMI Jeeper
Yj electrical problem with headlights and cd player
I have an '87 YJ. A few days ago I had my bikini top on and my Jeep got pourned on pretty bad during a thunder storm. I drove it home and everything worked fine. As I was going to leave a few hours later, the cd player was getting no power, and the headlights and brakelights would not work. I checked the fuse box but couldn't find the fuses for either. I am also in the process of moving and can't find my Haynes manual to help figure out the problem. I'm thinking it could be maxi-fuses but don't know much about it. Any help would be greatly appreciated. Thanks.
VMI Jeeper is offline
post #2 of 4 Old 07-02-2007, 08:55 AM
alexherb
Most likely it is a fuse. If you dont have access to a digital multimeter or a test light you can check them the hard way. Pull them one at a time and look to see if they are blown. When i get home tonight ill check the Haynes and see if i can narrow it down for ya. If you take it to a stereo shop like circuit city they would be able to check them and i doubt they would charge you but if they do itll only be maybe 20 bucks.
alexherb is offline
post #3 of 4 Old 07-02-2007, 02:01 PM Thread Starter
VMI Jeeper
I've checked every fuse (the hard way) and all of them are fine. I took it to an auto parts store and they are telling me that it is the light switch. I could understand that this might explain the headlights, brakelights and dash lights but I don't understand how the CD player is out too. I'm starting to think it is a wiring problem which means that I am going to be in for some fun times checking every wire.
post #4 of 4 Old 07-03-2007, 09:46 PM Thread Starter
VMI Jeeper
I fixed the problem earlier today. It turns out it was a burnt wire that was going to the relay. Took me about 5 minutes to fix. Thanks for the help.
Electrical problems with headlights/radio. Help txasylum Audio, CB & Ham Radios, GPS, & Electrical 1 04-11-2009 10:41 AM
CD Player Problem SVTCobraLTD Audio, CB & Ham Radios, GPS, & Electrical 6 06-30-2007 12:51 PM
problem with CD player bono426 Audio, CB & Ham Radios, GPS, & Electrical 2 03-27-2006 10:43 AM
CD player problem Ion Soul Audio, CB & Ham Radios, GPS, & Electrical 3 01-25-2006 02:24 PM
Odd CD player problem QuickZJ360 Audio, CB & Ham Radios, GPS, & Electrical 7 06-27-2005 08:32 AM
