Electrical Problem 97 TJ - JeepForum.com
post #1 of 4 Old 05-29-2009, 01:39 PM Thread Starter
sporttj
I started my jeep in the garage. It started fine. I pulled it out and moved it to air my tires up, then nothing. I couldn't even get a noise out of it. The dash lights wouldn't come on. I put a charger on it and tried to start it, still nothing. After a short charge, I would turn the ignition and hear the fuel pump go on, but still wouldn't start. I touched a wire from the battery to the starter and the jeep tried to start. It turned over, but would not start. I tried to start it with the ignition again, but this time, no fuel pump. The fuel pump wouldn't go on. I pulled the fuel pump relay and replaced it. Same problem. I jumped the relay by connecting wire and could make the fuel pump go on manually. I could even make the ignition click. With those jumped, I could then start the jeep. But, when I turn the key off, it stays running. I have to pull the relay jumper wires to kill the motor. I hear that there are tests to run to diagnose whether it is a broken wire or a bad PCM.
Has anyone had this issue? Could a bad battery cause these symptoms?
Any help would be appreciated.
sporttj is offline
post #2 of 4 Old 05-29-2009, 02:43 PM
mylt1
mylt1's Avatar
could be the battery cables. check them and make sure they are not corroded inside the cover and that they are tight.
mylt1 is offline
post #3 of 4 Old 05-31-2009, 10:58 PM
theGiantPanda
Swap This...
theGiantPanda's Avatar
check ALL your fuses and battery cables. double check the chassis grounds. sounds like when you installed the "jumpers' you were back feeding the ignition system and thats what was keeping on the jeep with the key off.. if its not battery/cables related, my first educated guess is theres a problem somewhere in the ignition circuit, maybe a main fuse, possibly the ignition clyinder could be bad. get a multi-meter. start there.
theGiantPanda is offline
post #4 of 4 Old 06-08-2009, 11:32 AM Thread Starter
sporttj
I've narrowed it down that I'm pretty confident that it is ignition related. I believe that it could be the ignition cylinder. I am going to check that next.
Thanks.
sporttj is offline
Electrical Problem? Islidur Audio, CB & Ham Radios, GPS, & Electrical 0 08-04-2008 09:54 AM
Electrical problem chainsaw620 Audio, CB & Ham Radios, GPS, & Electrical 2 09-28-2007 11:58 PM
Electrical Problem bfstewart3 Audio, CB & Ham Radios, GPS, & Electrical 5 07-19-2006 12:57 PM
need help, electrical problem cutlass1972 Audio, CB & Ham Radios, GPS, & Electrical 13 04-05-2006 01:54 PM
Electrical problem Guy Engines & Drivetrain 2 09-05-2001 09:13 PM
