Electrical problem - JeepForum.com
post #1 of 3 Old 09-28-2007, 04:29 PM Thread Starter
chainsaw620
Electrical problem
Hi so randomly my right front speaker went out (very little sound coming out) shortly after my CB blew a fuse and now when I replaced it seems to be short on power (dim light) and low speaker volume I tried replacing the speaker thinking it and the cb might not be related to no avail but if i put the ballence on my radio to the right it plays loudly but then the back speakers are not the same volume, all other things (as far as I know) are working radio fuse isnt blow and connections to back of deck are made. Thanks for your imput.
chainsaw620 is offline
post #2 of 3 Old 09-28-2007, 06:17 PM
SirGCal
RIP
SirGCal's Avatar
fuses blow because something shorted out. You might have damaged some wiring by the radio or speaker of heat was allowed to build up before the fuse blew. More important is to find out why the fuse popped to begin with. and work your way backwards to find the other related problems.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 3 Old 09-28-2007, 11:58 PM Thread Starter
chainsaw620
So I found out that its my deck (atleast for my speaker) put in a friends and it worked. Now I just need to find out if maybe somthing in the CB blew, It gets some power im guessing 1/6th of its normal power though
Electrical Problem 97 TJ sporttj Audio, CB & Ham Radios, GPS, & Electrical 3 06-08-2009 11:32 AM
Electrical Problem? Islidur Audio, CB & Ham Radios, GPS, & Electrical 0 08-04-2008 09:54 AM
Electrical Problem bfstewart3 Audio, CB & Ham Radios, GPS, & Electrical 5 07-19-2006 12:57 PM
need help, electrical problem cutlass1972 Audio, CB & Ham Radios, GPS, & Electrical 13 04-05-2006 01:54 PM
Electrical problem Guy Engines & Drivetrain 2 09-05-2001 09:13 PM
