electrical manuals/system maint. - JeepForum.com
post #1 of 3 Old 05-26-2004, 02:24 PM Thread Starter
scottishmage
who makes the best electrical manuals.
i have a 87 cherokee chief that has some serious electrical "issues"
i do low voltage work but i need a good set of diagrams and schematics.
the main issue is that the key lock cylender does not reliably put everything in the on position. ie. the radio wipers blinkers and a/c blower wont work. sometimes the windows work if you can get it in just the right spot.
reciently it will not let the engine contenue to run, just as if you turned the key off, here again it must be in exactly the right spot. and its getting harder to find the sweet spot.
i plant replace the the switch further down the column at the end of the linkage from the ignition key.
i am pretty sure that isnt the only problem, but its a place to start.
any suggestions are welcome.
thanks
scottishmage is offline
post #2 of 3 Old 05-27-2004, 07:42 AM
SirGCal
RIP
SirGCal's Avatar
Sounds like that whole rig might have some rotten wiring.. Maybe a call to Painless is the faster, better option.. ?? Just a though. Duno for sure. Not familiar with those rigs too much... Don't see many..
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 3 Old 05-27-2004, 08:49 AM Thread Starter
scottishmage
thanks for responding, i was able to fix 95% of my issues by replacing the ignition switch. this also seems to have allowed the parts store folks to get a decent reading with diag. scanner. my poor baby sees to be ok...for the moment, at least. but hey that is what project trucks are for, right.
thanks,
K.
short in gmc jimmy electrical system lancer27 Audio, CB & Ham Radios, GPS, & Electrical 2 12-12-2009 03:06 PM
96 Cherokee won't start-electrical system shuts down. JHAWK_XJ Audio, CB & Ham Radios, GPS, & Electrical 1 07-08-2009 08:08 PM
Advice needed for electrical system byteHeed Audio, CB & Ham Radios, GPS, & Electrical 3 08-11-2008 12:41 PM
BAD *** electrical system.....getting started USAFCOP Audio, CB & Ham Radios, GPS, & Electrical 0 02-22-2006 09:58 PM
Nextel phones and the TJ electrical system AbsolutEdge Audio, CB & Ham Radios, GPS, & Electrical 13 07-08-2005 12:17 PM
