Electrical issue? - JeepForum.com
post #1 of 6 Old 03-31-2012, 10:56 AM Thread Starter
PCRIDE
2004 XJ Cherokee
Electrical issue?
He other day I left work, tried starting the jeep and nothing ... No power, lights nothing. Like the battery was pulled out. This happened a while back and magically it just worked after waiting 10 min. Today it would start, the gauges were flickering and I could here the relay switches bouncing. As soon as I pressed the break everything lit up, internal lights came back on and it started right up. Before when I finally got it started after work, as soon as I hit the gas it died, it was almost like it was running on 3 cylinders, it finally started and I drive home.
History
Long ago (3years)I borrowed my friends trailer, he wired up the end wrong and it shorted out the body harness module, the dealer fixed it at 2200$ Do you think this could be a short in the electrical?
I have the alternator and battery tested and they are fine. Please see the video of the electrical gauges freaking out.
PCRIDE is offline
post #2 of 6 Old 03-31-2012, 11:34 AM
gily25
Anything new recently? Any other problems besides the electrical? Look for the threads here about grounds and start checking grounds. Check your battery terminals.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #3 of 6 Old 03-31-2012, 11:40 AM
SirGCal
SirGCal's Avatar
Yup, check all parts of the battery terminals.. Contacts at the battery, and at the fuseblock and frame. That's my first point of diagnostic. Make SURE it's all tight, clean and the wire isn't hard/stiff/etc. If those check out, move backwards into the rest of the system starting with system grounds throughout.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #4 of 6 Old 03-31-2012, 02:18 PM Thread Starter
PCRIDE
2004 XJ Cherokee
yea no changes, this only happens like once every few months. THis is the 3rd time in 6 months.
I did notice the battery terminal looks burnt where it connects to the battery connector, but on the wire. I am wondering if the red battery connector is bad, however when I took the terminal off and put it back on, it didn't change anything. It started when I pressed the break in while the key was turned 1 click. I am guessing its something in the wiring at the body control module or fuses.
Can someone tell me the main places to look? There are so many blocks of wiring I am not sure what I am looking at nor what it does.
So far I have seen
Fuse box under the steering wheel
fuse box under the hood by the battery
electrical panel on the firewall under the hood with a bunch of connections
If I trace the red battery wire, I presume that connects to all these electronics, something is loose I bet....
PCRIDE is offline
post #5 of 6 Old 03-31-2012, 02:20 PM Thread Starter
PCRIDE
2004 XJ Cherokee
The other thing, there hasn't been any rain that could have gotten wet, nor did I take it wheeling or anything out of the norm....
very weird...
Thanks for all the help, keep posting if you have any other ideas!!!
PCRIDE
PCRIDE is offline
post #6 of 6 Old 03-31-2012, 03:50 PM
JPNinPA
As mentioned check connections and grounds. Look at the wires sometimes they corrode from the connector up the wire. The grounds there are two sides to them at the battery and at the tub at the engine and tub to frame. Clean and sand both to a shine the wire end and where it's connected. It is likely you have a bad ground.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
