Electrical & Idling Problems - JeepForum.com
post #1 of 7 Old 10-06-2013, 08:57 AM Thread Starter
reedy922
I have a 2001 Jeep Grand Cherokee Laredo with a 4.0L and am experiencing some issues. While driving, all my gauges stopped reading and every light on the dash came on. On top of it, now the Jeep will start and then idle for 2-5 seconds then stall. The instrument cluster was swapped with a working used one and i still have the same issues so I'm guessing that's not the issue. I'm at a loss as to whether i should be searching for a loose ground/shorted connector or look at replacing the computer.
reedy922 is offline
post #2 of 7 Old 10-06-2013, 03:12 PM
yogi22
If the gauges all stop working you could be looking at either the crank position sensor and in rare cases the O2 sensor shorting to ground can sometimes prevent the clocks working and create running/idling problems
Hope this helps
yogi22 is offline
post #3 of 7 Old 10-06-2013, 07:28 PM
JPNinPA
Connector on the inst cluster may be loose. Clean TB and IAC. Make sure the connections to the IAC and TPS are good. A bad iac, TPS or crank position sensor will cause the engine to fail.
Any CEL or codes?
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #4 of 7 Old 10-13-2013, 07:07 AM Thread Starter
reedy922
If it was the crank position sensor, wouldn't that prevent the jeep from starting all together as opposed to starting then stalling.?
reedy922 is offline
post #5 of 7 Old 10-13-2013, 07:09 AM Thread Starter
reedy922
connector on the instrument cluster is tight and contacts are clean. throttle body and iac were cleaned a few months ago, so i suspect that there is no real issue there.
reedy922 is offline
post #6 of 7 Old 10-13-2013, 01:42 PM
JPNinPA
As they go out you may be running and stall out mid trip with no indication. They do not always fail completely all at once.
JPNinPA is offline
post #7 of 7 Old 10-13-2013, 01:48 PM
MoparMech
1995 XJ Cherokee
Usually when the gauge cluster acts up it is a result of a bus failure. THis can be caused by a shorted to ground o2, crank,cam, iac, TPS sensors. If you take a scan tool and try to read codes and the scan tool cannot talk to the PCM than it is a communication bus problem.
MoparMech is offline
computer , electrical , gauges , stalling
