Quantcast Electrical gurus and foglight gurus... - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Electrical gurus and foglight gurus...
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 01-19-2007, 08:13 PM   #1
dali555
I bought a TJ and previous owner put on Hella 500 foglights. He installed a crappy switch near the steering wheel. I went and bought the factory fogllight switch and found that the connection is there behind the dash. What I need to know... should I just splice the wiring or does someone know where the factory wiring goes and can I hook them up to that for safety purposes and neatness?
Thanx,
Marc
2008 JK Unlimited X, Red Rock... A.K.A REDRUM!
1997 TJ Automatic, White Exterior and Hardtop, Sport 6cyl. SOLD Nov. 2009
1986 CJ7, Black... Lots o' Rust.... SOLD 2005
1969 Mach 1 Mustang 428CJ.... show car.... my BABY!!!
dali555 is offline   Reply With Quote
Old 01-19-2007, 08:56 PM   #2
madrabbitt
if the factory wiring is there, you may have luck finding two wiring harnesses out by the bumper ends.
i'd tie into one of those to trigger the relay in the existing kit.
i would not use the OEM wiring direct to the lights though
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 01-20-2007, 02:46 PM   #3
dali555
For the Hellas I have 3 plugs... one is green (ground), red (power to battery) and 2 black wires that go into one (connects to lights).... which of the factory wires do I tap these into? I think I saw green on the factory connector so I guess that would be ground.... any ideas on the others?
Thanx,
Marc
Old 01-20-2007, 03:51 PM   #4
madrabbitt
if i remember correct, off the hella relay you should have the green wire which is the trigger, the thick red which goes to the battery, and the twin blacks which go to the lights, right?
In that case, the green wire goes to the + on the existing harness.
Old 01-20-2007, 08:39 PM   #5
dali555
Sounds right... which wire is the + wire on the factory.... where do I splice the other two wires... black and red?
Marc
Old 01-21-2007, 02:05 AM   #6
madrabbitt
get a test light to see which one is the positive on the factory harness.
Old 01-21-2007, 07:52 AM   #7
dali555
thought you were talking about the hella lights with the thick red and twin black... didn't know you were talking about the factory.... and this comment "get a test light to see which one is the positive on the factory harness.
" this is why I am writing to see if anyone knows because I am not a wiring/test light guy.... I probably could figure it out with enough time but wanted to see if anyone knew on here.
Marc
Old 01-21-2007, 12:16 PM   #8
madrabbitt
someone on here might know
what are the two colors on the factory harness?
On the cherokees its green and black, green is the +, black is the ground.
Test lights are easy though. You clip the end to something grounded like a bolt or the frame, and you stab the pointy end into the wire that you think is positive, and if it is, and theres power, the light turns on.
Old 01-21-2007, 07:45 PM   #9
dali555
Thx I guess I will go by a test light and poke around.... any ideas where the other two wires from the hellas go? the black and red? I just went down stairs and looked at where the green wire went from the Hellas and it goes through the firewall and bolts to the underside of the hood for what looks like a ground? I am getting confused.....
Can anyone just tell me splice green to "blank", red to "blank" and blacks to "blank"....
Sorry I need the wiring for dummies version.
Marc
Glock Forum
