Quantcast Electrical Gurus.. Aux Lighting Wiring Help - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Electrical Gurus.. Aux Lighting Wiring Help
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 01-16-2006, 07:58 PM   #1
mYJ
Time for a major upgrade. Living in the mountains my stock 6054 lights suck and just don't cut it. I'm getting Hella 500 fogs for the bumper, Micro FF driving lights for mounting in the grill where the turn signals are, and a H4 6054 headlight upgrade.
I would like to wire them up so the fogs come on with the headlights and the driving lights come on with the high beams. I would also like an inline switch so I could stop this if I needed. Also I'm getting the higher wattage H4 bulbs and am told I need to run a direct power supply to them to do this.
I'm an electrical noob so could one of you gurus draw up a wiring diagram on how I could do this.
-Jeffrey-
[SIZE=1]92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.[/SIZE]
[FONT=Impact][SIZE=2]Black JeepClub V2.0 #33[/SIZE] [/FONT][FONT=Tahoma] - Me & Roy[/FONT]
mYJ is offline   Reply With Quote
Old 01-16-2006, 10:47 PM   #2
kencaz
Here is how I would do it:
Good Luck
KC
My Cherokee
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline   Reply With Quote
Old 01-18-2006, 11:28 AM   #3
Scrambler82
Scrambler82's Avatar
1982 CJ8
mYJ, how'd this work out ?
Scrambler82
Do it right the first time !
Scrambler82 is offline   Reply With Quote
Old 01-18-2006, 01:09 PM   #4
mYJ
Just picked up the Hella 500 fogs and some new motorcycle flush mount turn signals to relocate to the fenders for this weekends project. After that I'll be picking up the Micro FFs for the turn signal buckets. I'll let you know how it goes.
-Jeffrey-
Old 01-19-2006, 11:44 AM   #5
SirGCal
SirGCal's Avatar
In a TJ, you have the factory fog cutoff relay which you can use to run fogs low beam and driving high-beam very easily which is what I did. Simply use the unused output of the relay to trigger the switch circuit for the driving lights.
I do not know if a YJ has this relay or not.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 01-23-2006, 05:05 PM   #6
mYJ
Well finished phase one this weekend with the 500s and new turn signals. Big difference already with the Micro FFs coming up next.
It was easy, thanks for the diagram kencaz
-Jeffrey-
Old 01-24-2006, 08:04 AM   #7
Scrambler82
1982 CJ8
Originally Posted by mYJ
Just picked up some new motorcycle flush mount turn signals to relocate to the fenders for this weekends project.
Give us a pic of these turn signals; please...
Scrambler82
Glock Forum
