Electric fan, P1491 - JeepForum.com
post #1 of 3 Old 03-26-2013, 03:51 AM Thread Starter
aroxishter
Electric fan, P1491
On my wj was not an electric fan, the old owner removed it.
check engine light(P1491). I installed the new fan and set the fan relay.
Still light, check engine, start the engine and the fan starts to work immediately. Clear the error (P1491) but it appears again.
The wires are good.
What may be the problem, the bad PCM?
aroxishter is offline
post #2 of 3 Old 03-27-2013, 06:29 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
P1491 Rad Fan Control Relay Circuit. An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays.
I would guess that there is a short circuit or open circuit in the wiring that powers the e-fan, or the wiring that tells the PCM to turn the fan on. Check the wires and wire plug at the Coolant Temperature Sensor and test or replace the CTS.
CJ7-Tim is offline
post #3 of 3 Old 06-06-2013, 05:04 AM Thread Starter
aroxishter
Bought new PCM, all problem was gone.
