Double whammy - JeepForum.com
post #1 of 14 Old 06-19-2013, 09:06 PM Thread Starter
Rican142
Double whammy
Ok, 1) for some reason a farting noise that is mimicking my exhaust is playing through my speakers, the faster I go the higher pitch is gets, and it shifts and all 2) I get REALLY bad pickup on pretty much all stations, I get about 3-5 clear stations
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #2 of 14 Old 06-20-2013, 12:34 AM
JPNinPA
Check radio ground and antenna connections and ground.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #3 of 14 Old 06-20-2013, 01:34 PM
gily25
Bad ground loop, could even be phone interference, check all stereo grounds, if you have RCAs for any reason make susre they don't run close to power wires.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #4 of 14 Old 06-20-2013, 06:15 PM Thread Starter
Rican142
RCA's?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #5 of 14 Old 06-20-2013, 08:02 PM
JPNinPA
Speaker wire and connectors come in RCA type like on an old VHS or stereo may even be on the back of the TV.
JPNinPA is offline
post #6 of 14 Old 06-20-2013, 08:25 PM Thread Starter
Rican142
Hmmmm... I've got one of them, their yellow red and white. Any idea why?
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #7 of 14 Old 06-20-2013, 10:06 PM
JPNinPA
The color coding on a VCR, DVD... Is for (red) right channel, (white) left channel and (yellow) video.
You have these on the radio?
JPNinPA is offline
post #8 of 14 Old 06-20-2013, 10:18 PM Thread Starter
Rican142
Idk WHAT their connected to, but I know their there
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #9 of 14 Old 06-20-2013, 10:23 PM Thread Starter
Rican142
I know the red yellow and white connections arent running to anything. Their just their, I don't know what the other end is connected to
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #10 of 14 Old 06-20-2013, 10:26 PM
JPNinPA
Stock radio? Do you have a subwoofer in the center console or a sub somewhere?
Did you check the radio ground? Antenna connections?
JPNinPA is offline
post #11 of 14 Old 06-20-2013, 10:46 PM Thread Starter
Rican142
No, it aftermarket, I got a sub in the trunk.
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #12 of 14 Old 06-20-2013, 10:47 PM Thread Starter
Rican142
And no, u haven't checked either, I'll be diggin in there tomorrow
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #13 of 14 Old 06-21-2013, 09:47 AM
THespos
If your grounds are okay and you've separated your RCAs from your power wires, you might have some success with a ground loop isolator. You can get them for under $20. I had one installed in and old VW Beetle with an aftermarket stereo. Grounds all seemed okay and we ran our RCA cables to the sub away from the power wires, but were still getting a farting noise coming through the speakers that changed pitch with higher engine RPM. The ground loop isolator cleaned it right up.
THespos is offline
post #14 of 14 Old 06-22-2013, 02:22 AM Thread Starter
Rican142
Well. I went in and found aaaaall this stuffed in there...while I was at it I swapped out my old kenwood stereo for my moms newer pioneer, thing works great and the farting noise is gone. I have no doubt that something was grounding out or pickin up some electrical somewhere. Not good
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
