Double Din help please - JeepForum.com
post #1 of 5 Old 02-20-2007, 06:52 PM Thread Starter
froggo27
froggo27's Avatar
I have this sitting around:http://www.alpine-usa.com/US-en/prod...model=IVA-W200 and wanted to know if anybody has done a double din work on their Jeep, i have an 04 GC Limited and just need to put this thing in. I went to an audio shop and they told me thats a no go because of the vents, i know i've seen this done before. Please post pictures for me and how it was done and if it can realy be done.
Kamil
04 WJ Limited
froggo27 is offline
post #2 of 5 Old 02-20-2007, 10:55 PM Thread Starter
froggo27
froggo27's Avatar
nobody has ever put a double din in their Jeep?
Kamil
04 WJ Limited
froggo27 is offline
post #3 of 5 Old 02-21-2007, 02:59 AM
Remoot
Remoot's Avatar
2005 WK
Jeep radios are din 1 1/2 so the double din won't fit, unless you break out the sawzall
Ma pole midagi valesti teinud
Remoot is offline
post #4 of 5 Old 02-21-2007, 05:03 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I have never done this but the idea is interesting.
You will need to open up the Radio Opening, don't know what is below or above the radio but look and see.
If there is a contour to the dash then a spacer will have to be fab'd to fit the dash and allow a flat mounting surface for teh HU or you might be able to sink the radio in the dash and fab up a panel to cover up any excess opening.
Wiring should be the same, so I don't see a problem, but the vent thing is another thing. You should be able to move the vents some but it will depend on your fabrication skills.
I think the level of expertise for this project is high but if you feel up to it or you don't mind screwing things up a little then try it out.
Luck and take your time and plan the project out completely first before ever cutting a thing.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #5 of 5 Old 02-23-2007, 04:59 PM
TheNerd
TheNerd's Avatar
Different application, but the same result. Check this out:
http://www.mp3car.com/vbulletin/show...highlight=jeep
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
double din in ZJ 96liftedzj Audio, CB & Ham Radios, GPS, & Electrical 0 01-22-2010 04:36 PM
Double DIN radio in a WK z0lt3c Audio, CB & Ham Radios, GPS, & Electrical 1 10-05-2008 08:32 PM
1.5 din --> Double din? Mark v Audio, CB & Ham Radios, GPS, & Electrical 0 05-27-2007 07:50 PM
double double cardan? Vacant Stare Engines & Drivetrain 2 12-12-2006 05:32 PM
Double DIN? dejablu311 Audio, CB & Ham Radios, GPS, & Electrical 6 06-08-2005 11:37 PM
