Do you think this alarm system would work in a jeep? - JeepForum.com
post #1 of 2 Old 10-06-2011, 05:47 AM Thread Starter
ILoveMyJeep1996
This might sound weird but I found an airplane alarm system, but I think I can modify it very slightly to make it work in my jeep... but I need to know if you guys think it would work, and what you think I would need to do to get it to work?
The instructions say
"You will require #22 AWG wire to install this unit. Mount the alarm in an out of the way location, where it is convenient to run wires to the door switches and the system on-off switch. When the location has been selected (4) #8 sheet-metal screws or rivnuts will be required for mounting. The On-Off switch should be hidden from view. The door switches are installed so the contacts will be closed (switch button depressed) when the doors are shut. Each door switch requires (2) #8 screws for mounting. This alarm system will activate any time this circuit is opened, and begins its 20-40 second time delay. Since this alarm system is designed to operate when the master is off, it is necessary to obtain power directly from the battery. A fuse, not to exceed 5 amps, should be installed as close to the battery as possible.
When exiting aircraft: Door must be open when you turn system On-Off switch to "on" position (this puts the alarm in a ready state). System will not be armed until you have exited aircraft and closed all doors.
When entering aircraft: Open door and turn system switch off. 20-40 second time delay allows you to do this before the alarm activates siren and strobes. This delay is Fail-Safe because you can only stop the alarm by flicking the switch "off".
I'm assuming I can just wire up the switch censors and mount them right under the inside nuts from the door hinge bolts, and when the door is closed the door will push the switch into the depressed position, and when the door opens the alarm will be activated if its not turned off in 20-40 seconds. This alarm is hooked up to a siren and a strobe light, but I'm assuming I can just ignore the strobe light part...
Does this sound like I could make it work?
I can provide more details if needed...
I will be posting pictures and scans of the instructions in a few minutes or half an hour at the maximum...
Some say the glass is half empty, Some say the glass is half full, I say "are you gonna drink that?"
Where there's a will, there are five hundred relatives.
For Sale: Parachute. Only used once, never opened, small stain.
ILoveMyJeep1996 is offline
post #2 of 2 Old 10-06-2011, 07:01 AM
athos76
You could probably wire the door switch in with the stock door switches. I have installed a few aircraft alarms in the past few years, and they really aren't worth much. Having a strobe and siren on an airplane is a bad idea. One of my customers had one activate in flight, and the switch was out of his reach. I didn't install it, but he had me remove it that day.
Most aircraft owners are more worried about their electronics than the airplanes. Some radios in the aircraft go for over $1000 each.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
replaced jeep alarm keypad batteries, doesn't work still jello Audio, CB & Ham Radios, GPS, & Electrical 2 12-10-2008 03:09 PM
Alarm System Help GLANGA88 Audio, CB & Ham Radios, GPS, & Electrical 12 01-15-2008 01:38 PM
The best alarm system jeeper01 Street Jeep Forum 3 10-09-2006 09:52 AM
Alarm system blalock Audio, CB & Ham Radios, GPS, & Electrical 17 09-07-2006 09:14 AM
Best Jeep Alarm System ??? DavesMatthew Audio, CB & Ham Radios, GPS, & Electrical 5 07-11-2004 09:45 AM
