do you really need to buy the $64 hella offroad wiring harness?? can't i make my own? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > do you really need to buy the $64 hella offroad wiring harness?? can't i make my own?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-28-2008, 09:57 AM   #1
bortz1892
i feel like i can do this way cheaper than the hella nice plug and play deal. i'm putting 4 hella 4000's up on a light bar, the wiring harness says it's good for only 2 lights, so i'd have to buy 2 $64 harnesses for 4 $126 lights!! yeah right. and then i'd have 2 switches for those 4 lights because they can't all be wired to the same switch....i'm guessing it'll get to hot?? i don't know. how have you guys wired your auxillary lights, what relay's have you used, where are you drawing your power from, where are you grounding? i need some light bar basics/aux lighting basics...any help or explainations would be greatly appreciated...thanks alot.
i have a 98' 2,5L manual TJ.
bortz1892 is offline   Reply With Quote Quick reply to this message
Unread 07-28-2008, 10:03 AM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
$64 for a harness is too high, KC's wiring harness is priced at less than half of that and they are essentially identical. A 3 second search using www.froogle.com/ produced this... http://www.google.com/products?q=KC+...Search&show=dd where you'll see several at $28.99 on the first page, maybe there are more for even less past the first page of that search result.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 07-28-2008, 10:39 AM   #3
bortz1892
my question i guess is: can i wire all 4 lights somehow into 1 switch.
Unread 07-28-2008, 11:24 AM   #4
Jerry Bransford
Administrator
Yes if they are 50-55 watt lights but no if they are 130-150 watt lights.
Getting Savvy...
Unread 07-28-2008, 11:29 AM   #5
bortz1892
so i must run 2 switches for the light bar?
Unread 07-28-2008, 11:31 AM   #6
Jerry Bransford
Administrator
Once again, it depends on the wattage of each of your lights. Do you know what their wattages are?
Getting Savvy...
Unread 07-28-2008, 11:49 AM   #7
monstermack
if you're running a relay in between the switch and the lights then you can use 1 switch for all 4 lights. You'll just need to split the switch output to 2 relays.
If you don't care where you're going, any road will get you there.
monstermack is offline   Reply With Quote Quick reply to this message
Unread 07-28-2008, 11:50 AM   #8
FitchVA
Jeeper 4 Life
FitchVA's Avatar
you could run 100 lights from 1 switch. ...it's the number of relays that count
like jerry was saying, if they're 55w'ers, then you can run 4 from 1 relay triggered by 1 switch. if they're higher, you should run 2 relays triggered from 1 switch
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote Quick reply to this message
Unread 07-28-2008, 11:50 AM   #9
FitchVA
Jeeper 4 Life
FitchVA's Avatar
beaten by mere seconds lol.
Unread 07-28-2008, 12:01 PM   #10
bortz1892
yeah i'm thinking about running 4 100x hella's...2 cornering beams and 2 pencil beams.
Unread 07-28-2008, 12:13 PM   #11
bortz1892
would anyone have a diagram of that by any chance?
Unread 07-28-2008, 12:13 PM   #12
Jerry Bransford
Administrator
100x means 100 watt? Ya have to start thinking/talking in watts here.
Getting Savvy...
Unread 07-28-2008, 01:30 PM   #13
bortz1892
sorry...that was supposed to be a 'w'. yes 4 100 watt lights.
Unread 07-28-2008, 01:43 PM   #14
Jerry Bransford
Administrator
Good enough, that confirms you need two relays since you want to run four 100 watt lights. A single pair of 100 watt lights draw pretty close to 17 amps and a relay is only rated to around 25 amps so you'll need a second relay for the second pair of lights.
Getting Savvy...
Unread 07-28-2008, 03:18 PM   #15
bortz1892
anyone have a diagram of a 2 - 25 amp relays operated by 1 switch?
