do you really need to buy the $64 hella offroad wiring harness?? can't i make my own? - JeepForum.com
post #1 of 17 Old 07-28-2008, 08:57 AM Thread Starter
bortz1892
i feel like i can do this way cheaper than the hella nice plug and play deal. i'm putting 4 hella 4000's up on a light bar, the wiring harness says it's good for only 2 lights, so i'd have to buy 2 $64 harnesses for 4 $126 lights!! yeah right. and then i'd have 2 switches for those 4 lights because they can't all be wired to the same switch....i'm guessing it'll get to hot?? i don't know. how have you guys wired your auxillary lights, what relay's have you used, where are you drawing your power from, where are you grounding? i need some light bar basics/aux lighting basics...any help or explainations would be greatly appreciated...thanks alot.
i have a 98' 2,5L manual TJ.
bortz1892 is offline
post #2 of 17 Old 07-28-2008, 09:03 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
$64 for a harness is too high, KC's wiring harness is priced at less than half of that and they are essentially identical. A 3 second search using www.froogle.com/ produced this... http://www.google.com/products?q=KC+...Search&show=dd where you'll see several at $28.99 on the first page, maybe there are more for even less past the first page of that search result.
Jerry Bransford is offline
post #3 of 17 Old 07-28-2008, 09:39 AM Thread Starter
bortz1892
my question i guess is: can i wire all 4 lights somehow into 1 switch.
post #4 of 17 Old 07-28-2008, 10:24 AM
Jerry Bransford
Administrator
Yes if they are 50-55 watt lights but no if they are 130-150 watt lights.
post #5 of 17 Old 07-28-2008, 10:29 AM Thread Starter
bortz1892
so i must run 2 switches for the light bar?
post #6 of 17 Old 07-28-2008, 10:31 AM
Jerry Bransford
Administrator
Once again, it depends on the wattage of each of your lights. Do you know what their wattages are?
post #7 of 17 Old 07-28-2008, 10:49 AM
monstermack
if you're running a relay in between the switch and the lights then you can use 1 switch for all 4 lights. You'll just need to split the switch output to 2 relays.
If you don't care where you're going, any road will get you there.
monstermack is offline
post #8 of 17 Old 07-28-2008, 10:50 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
you could run 100 lights from 1 switch. ...it's the number of relays that count
like jerry was saying, if they're 55w'ers, then you can run 4 from 1 relay triggered by 1 switch. if they're higher, you should run 2 relays triggered from 1 switch
'98 xj sport (trail toy) |
'98 xj classic (dd'er) |
'89 mj tinker toy |
FitchVA is offline
post #9 of 17 Old 07-28-2008, 10:50 AM
FitchVA
Jeeper 4 Life
FitchVA's Avatar
beaten by mere seconds lol.
'89 mj tinker toy |
FitchVA is offline
post #10 of 17 Old 07-28-2008, 11:01 AM Thread Starter
bortz1892
yeah i'm thinking about running 4 100x hella's...2 cornering beams and 2 pencil beams.
post #11 of 17 Old 07-28-2008, 11:13 AM Thread Starter
bortz1892
would anyone have a diagram of that by any chance?
post #12 of 17 Old 07-28-2008, 11:13 AM
Jerry Bransford
Administrator
100x means 100 watt? Ya have to start thinking/talking in watts here.
post #13 of 17 Old 07-28-2008, 12:30 PM Thread Starter
bortz1892
sorry...that was supposed to be a 'w'. yes 4 100 watt lights.
post #14 of 17 Old 07-28-2008, 12:43 PM
Jerry Bransford
Administrator
Good enough, that confirms you need two relays since you want to run four 100 watt lights. A single pair of 100 watt lights draw pretty close to 17 amps and a relay is only rated to around 25 amps so you'll need a second relay for the second pair of lights.
post #15 of 17 Old 07-28-2008, 02:18 PM Thread Starter
bortz1892
anyone have a diagram of a 2 - 25 amp relays operated by 1 switch?
Best wiring for hella fog lights ytownxj Audio, CB & Ham Radios, GPS, & Electrical 1 01-04-2010 12:02 PM
Another Hella 500 wiring question syphonation Audio, CB & Ham Radios, GPS, & Electrical 3 01-23-2009 03:43 PM
hella 500's with no wiring harness, what to do? alecmcmahon Audio, CB & Ham Radios, GPS, & Electrical 3 09-29-2008 05:32 PM
Wiring Hella 500s JeeperAbe Audio, CB & Ham Radios, GPS, & Electrical 1 03-29-2008 02:29 PM
Hella 500 wiring matt0360 Audio, CB & Ham Radios, GPS, & Electrical 12 01-05-2006 03:44 PM
